ROH wheels with 4th gen rear
Allright guys i just got my 2000 ws6 rear end for my 86 z28 and my next big purchase is going to be a set of ROH snyper rims..... will i need spacers for the front wheels? also will the offset be correct? i am sure someone is out there with a set of ROH"s and a 4th gen rear that could give me some info...
allright thanks guys.... haha yeah ive got my fingers crossed for the t5 still, holding up good so far though, hopefully long enough until i can find a 6 speed for a reasonable price if there is any that are reasonably priced im beggining to think there isnt.
Supporter/Moderator
Since you're going with the 4th gen rear, I'd go with the 17x9 Snypers with the 4th gen offset on all four corners. You'll need a pair of 2" adapters (I keep in stock) for the front rims, which will let you rotate the tires. If you burn off the tires before it's time to rotate, you could go with a set of 4th gen offset 17x9's for the rear and 3rd gen offset 17x9's for the front. *Or*.... you could run the third-gen offset on all four corners, and have the rear wheels a bit wider. It should be just about even with the edge of the fenders, similar to running the 17x11 ZR1's. Got a 3 faced coin to flip?
http://www.skulte.com/rims.html
http://www.skulte.com/adapterfaq.html
i like the 17x9 all the way around idea, but for now will i be able to use my 92 rims with the 4th gen rear end? I dont quite have enough for the ROH snypers yet and just want to be sure i can use my third gen rims with my new rearend.
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
kah992
08-19-2015 02:55 PM
