Thanks to Brandon Vana
Car: 1987 IROC-Z; 2012 Ford Raptor
Engine: Modified 350
Just wanted to say that the Tech Articles section has an article about repairing the loose and sloppy A/C vents with velcro and it works GREAT. While I had the vents out I used a Q-tip to clean the vents and the dash ports. What a great difference to have those units stay where you put them and the look is great! This is definitely a worthwhile 1-hour job to do all six including cleaning. It cost like $2.00. What a difference. I wouldn't have tried it without the article...Thanks again!
I would like to point out that the vents have a small button and a large button. Make sure you put them in the right orientation. Also, I used jewelers screwdrivers to minimize scuffing up the dash around the vents. The velcro I used was 1/2 inch diameter circles so I did not need to cut them.
