Shaving door handles myself
#101
1 Post
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Originally posted by z28_dave
so? deal with that fact that im not a nice person. this is the way i am and im going to continue to act the way i want to. you need to realize that not everyone is goin to be nice to you in the world and there are people that are going to step on you. im not going to go with behavior conformity, if thats the way this board operates.
i have no clue why u think i deleted a pm of yours.
wow looks like it took you awhile to write that. just to let you know i didnt even bother reading it because it would consume way too much time thanks for the pm
what brand of remote window controllers were u using?
i would say it to your face. why cant people express opinions around here? i might use different words (maybe) to your face, but id still get my point across to you.
https://www.thirdgen.org/techbb2/sho...133#post951133
im not goin to sift through a bunch of my past posts just so that u can make a point.
and im stating this now:
"i dont care what u think about me"
sounds familiar doesnt it?
#103
Location: tokyo - where the girls are pretty and the cars are fast
I know you claim to be Mr. Street Rodder himself, but you are not the only one with "street rodder" experience. If you drive your supposed Street Rods every day, I have to wonder if you know what a street rod is.
And you need to deal with the fact that you will be considered a low-life turd that isn't worth the effort to speak to if you continue on that bent. You wanna be stepped on? Do you like being stepped on? Do you like being talked down to? Do you like having people **** on things YOU like? I would say no to all. Because it MAY happen in day-to-day living does NOT mean it's okay to go ahead and do it because it'd happen anyway.
The main reason you don't see poppers on street rods is the fact that most are fiberglass (very light doors), and the poppers could easily damage the doorjamb.
So if that is so you will have to deal with others here not being nice to you.
Why? Should it?
Originally posted by LT1guy
We Don't Care If You Don't Like It!
Figures. A liar to boot.
#104
Car: See pic above
Engine: Too Small
Transmission: Broken
Originally posted by LowCamaro
ah yes,i totally forgot about that one,ive seen that kit in lowrider mag before.Now do they have two different kits,1 with heavy duty solenoids(35pounders)and 1 regular basic kit?AutoLoc and SPAL have those 2 options.I will be going with the 35lb kit just because of what guys have told me.I live i BC canada and a shop im going to be ordering the SPAL kit through is asking $225 canadian.The same kit is listed in truckin mag for $135 american.Im most likely going to go with the SPAL kit.
My advice would be to run a 10 gauge wire from the battery into the the passenger footwell. Then have a distribution block cause you have to run a wire to each solenoid, and then if you want to add power windows you have to tap into the power for the solenoid for the driver's side switch.
But it's definently worth it. I've gone from having completely manual doors to all power. Now there's just a power window switch and a little red button to open the door and that's it. It's a little weird cause people get into the car and they go, "wait, how I do I get out?" I'll try and get some pics of my new door panels up so you can see them. Hopefully it'll put all those with modified stock panels to shame
#105
1 Post
Originally posted by joezero
I went for autoloc for the door poppers and SPAL for the power windows. I got the 50 lb. solenoids, cause it was the same price as for the 30 lb. ones, and I have to say they are total overkill. Don't let them tell you that you have heavy doors and that you need a bigger solenoid, because the weight/size of the door really has nothing to do with it. The solenoid just pulls on the latch, which allows the door to open. Of course, you could always go with the biggest ones you find if you're into that bigger is better mentality. I personally get a kick out of the big thud they make when the doors open. Don't bother getting the actual poppers either, you won't need them and you have to put like a 1/2" hole in your car to mount them.
#106
Car: See pic above
Engine: Too Small
where did you end up mounting the poppers? I'd like my doors to pop open more than they do now, cause you have to grab it and pull it open before the solenoid releases. I figured the that when I replaced the weather stripping that it would provide enough added force, but I really want it to pop 2-3". The only spot on the body that looked like it might work was in the door frame right by where the seat belt bolts in.
#107
1 Post
[QUOTE]Originally posted by z28_dave
more or less with this statement....
and this one... so quaint!
That is in his sig not mine. Something in someone elses sig has nothing to do with me, so again why would your phrase bear any significance for me.
Hey Joezero, I would love to see pics of your door panels!
when did i say that i cared what other people said to me?
wow with rude realisations like this one, its no wonder u and joe (?) get flamed.
after these useless comments above, ill try and save this thread with some more info rather than attacks on individuals (ie: me).
shut up
yes - - ->
#109
Car: See pic above
Engine: Too Small
Originally posted by FLYNLOW92rs
z28 Dave............
This is for you..........
Shannon, this is a pic from the manufacturer of the door panel covered in blue tweed and on like a 32 ford. The panels actually come as black ABS and then you trim to fit. It's too bad that I had to extend the panel by a couple of inches, cause the texturing on it is an exact match to the interior panels. But it's got a big glue seam at one end so it's gonna have to get covered. I tried black vinyl, but it doesn't contour well enough, so I'm gonna go to a specialty store today and see what else I can find. I'm going to visit my friend this weekend and he's got a digital camera, so hopefully I'll get pics up at the beginning of next week.
#111
1 Post
You see the silver thing below the door latch in the door jam area (small in the pic) That is it! Works great there!
#112
1 Post
LMFAO!!!!!!
LMFAO!!!!!!
#113
Car: 1985 Camaro
Engine: ......
Transmission: ......
Hey thanx for answering some of my q's guyz!And doesnt it feel good to talk about the actuall thread topic! (lol) Well,i ordering the kit tommorow.Its supposed to take 1 to 2 week to get here.Im ordering the SPAL 35Lb kit for $225 Canadian.Cant wait till it gets here.Ill see if i can borow a digi cam for some before and after pics!Thanx again and i cant wait to see those panels joezero!
#123
Car: 1987 Trans Am
Are you getting the message that people here are going to treat you the way you treat others? If you insist on being an assh*le, you'll be treated like one. Don't want to conform, as you say? Fine. Just don't bitch about it when people retaliate. I would think that the pictures you're seeing posted are far better than the punch in the mouth you'd get in person.
#124
1 Post
Car: 00 TA, 91 Formula, 89 RS
This thread's had it coming for a while...
I am officially....
POOPING ON THIS THREAD!!!
I am officially....
#125
#126
I am officially....
I am officially....
#127
please think
A few of you guys on here need to just relax and go fight some where else. And it would also help if a couple of you thought before you posted,
My dad is dead, and yes it was by suicide, and when i come on here to learn about cars i dont need to be reminded of that.
you want some thing to post, get you camera and post some pics of what the topic is on, I know that there was no way that you would have known my past but at least be considerate and think about other peoples feelings before you start tossing insults.
Back on topic,
I shaved the handles on my car, sorry have no pics, I chose not to weld on my doors but to just skin the whole thing, i was reccomended this by a friend of mine who owns a body shop, just because it is so easy to warp a long door like we have.
( tip on welding thin steel--- place cold wet rag on all sides of where you are welding, it will absorb the heat and stop the warping)
As for the poppers, i got an autoloc kit, and it came with everything i needed, 35lb solenoids, all the relays, and the brain with 2 remotes and a hidden emergency button. I have not had a problem but i have also not used them when it was below 32*f. If you already have power unlock by remote, you can buy the solenoids and the relays and wire up the relays so that the factory unlock will trigger the relay and that will trigger the poppers. If you have anymore questions i will be glad to help because i have done this a few times now.
Bradford
Back on topic,
Bradford
#128
Car: See pic above
Engine: Too Small
Thanks for getting things back on topic black82z, I was beginning to wonder why I was even still subscribed to this thread.
Out of curiosity, where is everybody mounting the emergency switch? I was thinking of putting it in the little glove box in the trunk, cause I just don't feel safe mounting it somewhere where people could get to it (like right under the door).
Also, on my door panels, they're part cloth part vinyl, and I need to put something on it to cover up the seam, any suggestions? Thanks, Joe
#129
Car: 1985 Camaro
Engine: ......
hey thats not that bad an idea,in the rear lock box!How much did ya pay for the autoloc kit?i see your from good ol canada...me too!
#130
This is what it looks like without door handles or locks:
(BTW, if you don't like the car, think its rice, whatever...spare us all and just PM me! I'm sick of a few a-holes ruining good threads here!)
Anyways! j/k, shave the handels, but at some drag strips its a NO NO
#131
1 Post
Car: 89 Formula Firebird
Engine: 305 - Demon 525
I am officially....
I am officially....
No no you did it all wrong you have to do something like this.
AAAAAAAAHAHAHAHHahahahahah........
#133
Car: See pic above
Engine: Too Small
#134
Car: See pic above
Engine: Too Small
In regards to the ppl that are posting pics of excriment, this is a message board about cars, it's not those fetish websites that you're usually on. With that in mind, here are some pics that might be a bit more helpful.
#136
Car: See pic above
Engine: Too Small
I'm not real thrilled about the silver trim, but I needed something to cover up the seam. If anybody has any suggestions for something else, please let me know.
#138
1 Post
On mine when I added the nauga soft, I used red to transition b/w the grey and black. So you could use a contrasing trim color, or if you wanted it to blend in I would use black satin rope, like for necklaces. Typically you can get it from a hobby shop, but Walmart carries the stuff. Word of warning, don't pull it taut as you tack it down, once its in the car and the sun gets to it it will not stretch with the panels and it tends to pull out of place. I just laid mine down a bit loose it can stretch out with the panel.
#139
Car: See pic above
Engine: Too Small
Thanks for the suggestions, I'll have to try a black trim. I wanted to do the whole panel in blue, but I couldn't find any fabric that matched the blue that's already in the interior, so I figured I'd go with black. For those that are interested, this is a pic of the solenoid installed in the door. The little black box is the relay for the solenoid, and all the other wires/switches are for the power windows.
#140
Car: 1985 Camaro
Engine: ......
Thanks for that last pic joezero.Really shows how an where the solenoid is mounted!Ive got my new doorz and the kit is ordered...now all i need to do is install!
#141
1 Post
I'm not against the whole idea about the shaving door handles I'm just afraid the door might freeze shut in the winter or the key batteries die and you cant get in your car. The motor goes bad and dosnt pop...something like that.
#142
Car: See pic above
Engine: Too Small
Glad it helped, Lowcamaro. If you need pics of anything else, just let me know. I just got a digital camera and I'm going picture crazy.
#143
Car: 1985 Camaro
Engine: ......
JoeZero,what is it you are using that runs from the solenoid to the claw release(or whatever its called)Looks like a zap strap in the pic.
#144
Car: 1985 Camaro
Engine: ......
Oh and when you filled the door locks and handle holes,did you weld in a plate and the bondo over top or did ya fill the entire thing with body filler?
#145
Car: See pic above
Engine: Too Small
It's actually a steel cable with little metal clips that you crimp on. I wish it was something more like zip ties, cause that'd be easier to work with, although I'm sure they wouldn't hold up. And I haven't taken off the lockset/handle on the outside yet. I'm planning on having the whole car repainted, so I'm holding off doing it until I'm read to have the paint done. Although I wouldn't try and fill the whole thing with body filler. I had actually asked a while ago about using fiberglass, and was advised against it because you're trying to bond two dis-similar surfaces and it would eventually split.
#146
Car: See pic above
Engine: Too Small
I thought I'd post some new pics of the door panels in the car. Man, people really do freak out when they can't figure out how to open the door.
#148
Car: 1985 Camaro
Engine: ......
Hmmm,then i wonder what i should do...I was planning on going with a piece of sheet metal and tacking it into the holes and then putting the body filler over it.But...i dont have a welder any more!Hmm,i wonder if i could bond them with JB weld?RedRaif...what did you do?
JoeZero,those door panels are sweet!
#149
Car: See pic above
Engine: Too Small
Here's what LT1guy had posted earlier about how they did redraif's car. I thought I'd repost it since it was way at the beginning, and it was probably lost amongst all the bickering above.
We started by removing the handles and lock cylinders, and making posterboard patterns for the filler pieces. Make them as close as possible, so that when you duplicate the patterns with sheetmetal (we used a crunched door from a bodyshop scrap pile) there is very little gap. The smaller the gap, the less weld it will take, the less chance of warping the metal. Set your welder (MIG) on its lowest heat setting, and turn the wire speed low also..you may have to play with it a little. Tack weld the pieces in, skipping from one side to the other so as not to build up too much heat. Once the pieces are welded solid, dress the welds with a body grinder. If you did a good job, very little filler will be required. I would use a product like All Metal, or Marglass...they have greater strength than regular plastic fillers. Finish with epoxy primer and a skim coat of regular body filler if necessary. If you don't have access to paint equipment, spray over the area with paint to seal it until you have the door (or whole car) painted. Regular spray can primers won't seal out rust.
#150
Car: 1987 Trans Am
