Car vandalized! Need help...
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Some a$$hole splattered Super Glue or some similar substance all over my driver side door and window! Some of it got on my t-tops as well. I've tried adhesive remover, laquer thinner, and acetone on the glass surfaces to no avail. Does anyone know what I can use to get this stuff off the painted surfaces with. I can probably scrape it off the glass with little trouble, but I don't wanna f*ck up my paint if I don't have to.
Sorry to say this but if it ain't coming off your window with stuff as stong as Laquer thinner.. It sure as hell ain't coming off of your paint. I would use the window as a tester for how stong of stuff you really have to use.. but the paint for sure has to come off if laquer thinner isnt getting it off..
If its not coming off with Laquer Thinner.. You would have to scrub suuuupeeeer hard with a fine grit sand paper to get it off. Plus if the glue is "splattered on", your gonna have a bunch of sanding spot marks on the paint
1 Post
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Hang on I might of fould something on a web sites. Its this stuff you put on model cars to remove the glue with out hurting the paint.
for info= it says use debonder that will desolve glue and not harm paint.
http://www.scaleautomag.com/sca/feat...es/Glue101.pdf
Thats going to be hard to find. What I'm looking for on www.google.com for you is a <font color=red>debonder</font> that will removed the bonding agent found in super glue but will not hard paint. You could call a hobby store and explain the problem and see if they have the stuff. If you but it try it at the junk yard on a car to see if it does anything on the paint. You should let it sit for atleast 24 hours. Or you can try it on your X girlfreinds car hehe J\k.
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
have you tried a razor blade on the windows?? As far as the door, sorry to hear about that. Not sure what to say to that.
Linson
08-21-2015 02:12 PM
