Cleaning oxidized aluminum
I’m trying to clean up some turbocharger compressor housings and am looking for a quick way of getting the nasty oxidized look off of them. I’m trying to stay away from mechanical means because I don’t think I want them to look polished (that’s easy enough to do, just takes time and it wouldn’t match anything else).
I’m betting sand or bead blasting would work if I had access to a blaster…
Any ideas?
Any ideas?
Car: 86 T/A
Engine: 5.0 TPI
Bead blasting will give you a very even clean looking finish for a very short while. Then the porous surface you create will get dirty, greasy, grimey as all get out. I would just stick to a commercial aluminum polish to remove the oxidation.
Hotrodboba400
12-10-2019 07:07 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
09-06-2015 06:23 AM
