16 inch ROH Snypers or RS style IROC'S
16 inch ROH Snypers or RS wheels
Here is a pic of the car with 15 inch RS style IROC's
The next post will have the wheel I am looking at but its a 16 inch
What do you think I should go with?
David
Edit: Sorry guys I thought the pic showed more of the front wheel![Frown](https://www.thirdgen.org/forums/images/smilies/frown.gif)
Edit2: check this out instead https://www.thirdgen.org/techbb2/sho...threadid=94045
Scroll all the way down and you will see a white 84 Z-28 that looks just like mine but I have window tint and its a sport coupe. Do you think the 16's would look good?
David
Car: 89rs
Following is taken from skulte.com
The Snypers's are now available in 17x8" and 17x9" sizes with a 0mm offset for third-gens. The 17x9's will fit on all four corners as well. Running large tires up front in addition to the rear will help balance the understeer GM has designed into the F-bodies. This will reduce the push when cornering, balancing the car, and ultimately providing more grip for cornering.
SWEET
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
David
Car: '87 Z
Engine: 355 in the works
If you have the $ I'd go with 17x9 ROH Snypers. I couldn't afford them, so I got 85-87 model IROC wheels...
Street Lethal
04-30-2019 12:14 PM
mustangman65_79
08-11-2015 03:17 PM
