Miniram Fuel Pressure Regulator Fitting
The FPR on my miniram went kaput. I bought a LT1 FPR for a 96 camaro. How can I change the out fitting to AN6? The TPIS had a female adapter that connects to FPR, but the threads are different on the new FPR. It's a Delphi FP10004.
Re: Miniram Fuel Pressure Regulator Fitting
How are you determining the threads are incorrect? Are you sure there isn't some damage issue with the threads that's preventing the adapter from screwing on?
Reason I ask is I had been running a LT1 Camaro FPR on my Miniram for a while and that adapter screwed right onto it.
I've had the FPR for probably over 15 years, so I don't exactly recall a p/n or anything like that. Only that it was from a LT1 Camaro.
