Super Ram Fuel rail fitting help
I'm installing this setup into my car. It didn't come with the blue fuel rail fittings pictured. Can someone point me in the right direction as to what size and where to find them, or better yet, have a set they are willing to part with? Thanks in advance.
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: Super Ram Fuel rail fitting help
The Super ram uses stock fuel rails. If this is going in something that originally had a TPI you can use the original equipment stuff. If not, you will need to find the TPI rail to AN adapters.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
