Anyone have this fitting for Stealth Ram?
Re: Anyone have this fitting for Stealth Ram?
remove the one from the other side, and with the picture you have take it to a place that deals with hydraulic hoses, they'll have the elbow with Male an/jic but you may have to drill and tap it for the bleeder valve setup. Probably save you a lot of money vs buying from holley or others
You could always use a remote mounted regulator with a guage and of port for checking fuel pressure and just go to your rails with an fittings and lines
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
It's a standard fitting. -6 ORB 90 degree to -6 male with 1/8" npt thread gauge port.
basically this in -6
https://www.foreinnovations.com/product_p/200045.htm
-- Joe
-- Joe
-- Joe
-- Joe
GTAman
11-30-2015 11:12 AM
