Need a cam suggestion for Superram/AFR 180/350
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
Currently I have the CC304 and I want more power. I am looking at one the following 3 cams
cc305
cc502
cc503
I cant make up my mind so any suggestions would be great. Keep in mind I have a stock converter at the moment but i will probably get a 2400 stall converter before summer. Like I said suggestions would be appreciated and if anyone has 1st hand experience with any of these 3 they can share that would be great.
cc305
cc502
cc503
Car: 1986 Iroc Z 28
Engine: 383
Transmission: 4L60
Re: Need a cam suggestion for Superram/AFR 180/350
Your build is almost exactly the same as mine. I have Comp's version of the cc503 which is the XE268 cam. It is great for the Superram. In fact John Lingefelter specifically calls out these cam specs in his book for use with a Superram. Good luck!
Car: 1989 IROC-Z
Awesome, thanks for the advise. That is the cam I have been leaning towards, but I wanted to hear from someone who had experience with it.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Out of those choices 503 cam hands down, i'd even do it on a 110 lsa, that be the 276hr i believe. Or you can get alittle more aggressive with a custom xfi series 224/230 but will need afr 8019 springs imo
That must have been before he contracted with Accel/Erson to offer a line of roller cams for the Superram.
The only difference is that the Erson stuff only had smaller durations but the lobes and overall specs were influenced by John himself.
Car: 89 Iroc-z
Transmission: TH400
Lpe 219/219 has been a proven cam for superram setups
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
i still have my old LPE Stage 5 383 set up laying in the back of my shop.
mech roller cam made almost 500 hp with the super ram..
think a budy of mine is going to install the cam and lifters in one of his sbc soon.
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Comp makes a 220/230 HR cam that works fantastic
Crower same thing 221/230 wish I had the grind #s.
Picked up across the board coming from a 280 XFI (that went flat in under 20k, roller too!)
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I would vote for the cc503. But with a 350 and a head at 180 I would think it might be choking a little up top.
Car: 1989 IROC-Z
The motor is currently sitting with the intake and front cover off. I have decided on the 503. I have been slow milking this job for a while.
junkcltr
08-03-2019 12:12 AM
