383 stealth ram for autocross
1 Post
Car: 91 rs
Engine: 434 stroked v7 supercharger
Transmission: mad dogg 700r4
hey guys looking for a cam for my 385 stroker im using the engine for autocross heres what i have 385 10:7:1 compression ,210 vortech alu heads
stealth ram intake, 58mm holley tb,3400 stall converter ,373 gears, fast efi multi port computer system ,Msd 6al2 programmable im looking to get autocross performance and maybe take it to the strip some times im looking at the comp cams 268 or 280 xfi So cam help and exh size dual 2.5 or 3 running cats
Re: 383 stealth ram for autocross
Can't go wrong with the 280XFI, its what I have. Great midrange, good idle quality not to rough. I have manual with 3.42 but have been wanting to go to 3.73-93 as I think it would make crawling along much easier on the clutch. That 280 requires good high lift springs though. Many recommend the LS7 lifters with it, or is it 6?
The engine combo that is almost a mirror of mine is #16 and makes 491 horsepower 501 torque at the flywheel at street friendly 5,500 and 4,000 RPM. For AutoX will probably spend most of your time between 2,500 and 5,000 it seemed good enough for me. I will put mine on the dyno in the spring and hope to get 400/400 at the wheels. Look through that links pages and you can find some informative combos.
http://www.ryanscarpage.50megs.com/combos2.html
LT1Formula
10-08-2015 08:34 PM
