What cars came with Bosch 3 36lb injectors?
Just for the sake of asking i was wondering what cars actually came from the factory with Bosch 3 36lb injectors. I have 3 different junkyards/pick and pulls here in town and sourcing them probably wouldn't be that big of an issue. So there's my question, which ones did they come in? Any help would be more than awesome.
Engine: 4++,350 & 305 CIs
Re: What cars came with Bosch 3 36lb injectors?
Supercharged GTPs from around the late 90s or so. They have white tops i think.
1 Post
Car: 1988 Gta trans am project 1-1/2
Engine: 86 4 bolt main cammed sbc 355 hsr
Transmission: 89 wc bw t5
Axle/Gears: Bw 9 bolt (3.27) pbr 11in
So ur saying gtp injectors are 36lbs can these be used in the hsr fuel rails
bosch 0280155811 were used on
B5234FT/T3/T2
1999-04 C70 2.3
2003-04 S60, V70, SC70 2.5
2004 S60R, V70R 2.5
2004 S60-T5, V70-T5 2.3
1999-03 V70 2.3
2001-03 S60 2.3
1999-00 S70 2.3
1998 C70, S70, V70, R 2.3
http://www.fiveomotorsport.com/fuel-...ors/?itemid=71
B5234FT/T3/T2
1999-04 C70 2.3
2004 S60R, V70R 2.5
1999-03 V70 2.3
2001-03 S60 2.3
1999-00 S70 2.3
The GTPs are a good source for injectors, I will say I got a set of orange ones with EV1 connectors for ~$115 and they were new. You can get a set of Lightning 42s for ~150-200 if you look as well, and Cobra 39s are ~100 bucks but use EV6 connectors. I don't think you're going to do that well for a set of stockers. Anything that's old isn't really trustworthy, I had a set of GN 28.5s in my TPI that caused me all kinds of headaches because #2 was dumping fuel. JMO if you get anything used I'd assume on sending out for cleaning.
NBrehm
08-25-2015 11:49 PM
