Lt-1 injectors with hsr
1 Post
Car: 1988 Gta trans am project 1-1/2
Engine: 86 4 bolt main cammed sbc 355 hsr
Transmission: 89 wc bw t5
Axle/Gears: Bw 9 bolt (3.27) pbr 11in
I was wondering if lt-1 injectors would work with the hsr setup also wanted to know what year lt-1 injectors came 24 lbs the stock 21 tpi injectors wont hold up to my build im doing also what year lt-1 injectors will i need i seen something that 92-93 lt1 injectors are 22 lbs an the 94-97 are 24 can someone please confirm this with me
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Lt-1 injectors with hsr
Injectors will fit a HSR fine but injector ( size ) is selected depending on the engine fuel requirements , not the intake type
1 Post
Yes i know this i was told by my engine builder that 24 lbs injectors would work perfectly fine an hold up for my hp rating im trying reach 350 flywheel hp
jerflash
09-24-2015 03:11 PM
thejimsterz28
09-15-2015 04:37 PM
