HP/TQ ESTIMATES DYNO 2003 PLAUSABLE
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Hello there well i was bored and decided to mess with dyno2003 to see what estimate i would get for power i know its not accurate and that its calculating based on the perfect conditions, so it might be 20 or so HP/TQ less just a ballpark guess . and numbers doesnt include drivetrain loss at 19-20% this is at the flywheel
set up i have now is l98 stock everything except cam
Comp cam 8-501-8
Basic Operating RPM Range: 1,200-5,200 RPM
Duration at .050" lift: 212 int./218 exh.
Valve lift with 1.5 ratio: 0.488 int./0.495 exh. lift
9.5 CR
the next combo is same cam above but with lt1 intake and heads conversion 10.0 CR
the third combo is lt1intake and heads conversion with custom cam and 1.6 roller tips 10.0 CR
with duration 223/230 with lift at .570/.580
not exact specs of cam but its close lift should be around mid 500s
so heres what i got out of dyno 2003
what you think?
and again just bored messing with this
Comp cam 8-501-8
9.5 CR
what you think?
darwinprice
17
10-11-2015 11:51 PM
LT1Formula
10-08-2015 08:34 PM
manifoldsrme
09-17-2015 11:40 PM
