Safe fuel pressure
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Safe fuel pressure
I run Ford SVO #32 (red tops) @ 50psi (3.5bar) with 255 hp Walbro fuel pump.
What will be safe maximum fuel pressure for these injectors and fuel pump.
best regards
best regards
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Re: Safe fuel pressure
I'm have my Ford 30lb red tops pressure at 58psi, with vacuum line disconnected at idle. I spoke to SouthBay injectors about this a while back and they said my injectors at that pressure would perform like a 36lb injector at 43psi.
Thanks for input, while looking on the web i found two useful pages:
http://forums.evolutionm.net/evo-eng...pump-test.html
http://www.autoperformanceengineerin...l/fpspecs.html
best regards
best regards
R3500
08-17-2015 12:16 PM
92camaroJoe
08-13-2015 06:07 AM
