Custom made TPI intake (radical design)
Re: Custom made TPI intake (radical design)
:O wow lol...umm can I ask why? Would the tpi plenum and runners still be a restrictive intake...even with a carb ontop?
How does it run lol?
Car: 1991 Z28 1LE
Engine: LB9 305
Transmission: Borg Warner T-5
Axle/Gears: GM 7.5 3.42 Posi
No idea, I stumbled onto that on ebay many years ago and saved the pics. Its a classic for sure. I'm sure it probably ran ok for everyday driving but probably fell on its face above 4500 or so. Sure does look like ***. I loved it!
lol hell..it if was cheap enough on ebay..id try it for sure..just to say i did it
Engine: 4++,350 & 305 CIs
Saw pix of this a few years ago, what a wonderful way to do things backwards !!!!
Should this be in the carb, TPI, alternative port efi section or all of them???
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
wow.. I think I have scene it all now... a epic design... a revolutionary.. performance upgrade... I must have it???
Car: 1991 Z28 1LE
Engine: LB9 305
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
The TPI intake wasn't designed to have fuel flowing through it so I'm sure that engine would run very poorly. Cylinders 2, 4, 5, 7 would not get much fuel.
You would also need a massive cowl hood.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Bet it ran like a champ in the winter. Wonder how much fuel actually puddled up near where the throttle body was when it was cold?
1 Post
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
Ran into a situation a few years ago with a TPI setup in a streetrod where the extremely confined area at the front of the engine compartment was too narrow for ANY factory or aftermarket pulley setup to work. All of the options that were compatable with the TPI's aircleaner position were too wide, and all the options that fit the engine compartment interfered with the tpi air cleaner.
We entertained the option of modifying the manifold to a down-draft right in the center. Of course it would have still been EFI so there wouldnt have been the wet flow problems a carb would have in that position.
In the end we didnt do the down draft, but rather fabricated a new accesory drive setup.
When I saw that carb adaptor on the TPI manifold I had an instant flashback though. No beer was involved in this one.
Car: 84 vette 85 vette
Engine: 350 crossfire, 350 TPI
Transmission: both 700R4
Axle/Gears: 84 vette 3.07, 85 vette 3.54
There is a reason why it is on eBay.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Cost may have played a factor in this. But the more likely scenario was that the guy was trouble shooting a driveability issue over a few cold brown pops, but he was heading out the wrong branch on the trouble tree.
Then he remembered the old dusty carb he has out in his tool shed.
Car: 85 vette
Engine: 427 SHP block,AFR 210,MiniRam
Transmission: TKO 600
Axle/Gears: 3:07
If you look closely enough you can see the letters "BBK" near the carb base.
1992rs/ss
05-19-2020 07:02 PM
Fast355
12-02-2016 06:33 PM
kah992
08-19-2015 02:55 PM
Sanjay
08-12-2015 03:41 PM
