Weiand ram question
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
Weiand ram question
is the Weiand 7540 ram the right one for an 87 gta with a 5.7. also will this fit under my hood it looks a bit high for clearance
Received 1,839 Likes
Re: Weiand ram question
Looks like the right #; just be sure it's NOT the Vortec one, unless you're changing to those heads.
Yes there is a fitment issue. Problem is the TB: the HSR is parallel to the crank, and therefore angles upward at the front, which points the TB upward somewhat. I've heard of some people being able to notch out the hood reinforcemnt and make it fit and some that it still wouldn't. I've also heard of someone making a wedge-shaped TB spacer. Other than that, it fits.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Everything you need to know about the HSR is in the stickies at top of page
https://www.thirdgen.org/forums/alte...gal-whats.html
gixxer92
09-01-2015 04:32 PM
L98GTA87
08-11-2015 06:55 PM
