Stealth ram fuel rail questions???
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
If I buy the rail without a adjustable regulator can I later upgrade to one on these types of rails or not? Also it says I need a spacer to use my throttle body(92) which one do I need?
Axle/Gears: G92
Re: Stealth ram fuel rail questions???
I also have a Holley 52mm throttle body part number HLY-112-506 do I need a spacer for this one?
Axle/Gears: G92
One last question. How does the distributor mount to these?
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
92s have a small cap, remote mount coil so your good there, mounts just like stock. The regulator is removable, so no need to purchase another one to be adjustable. Best thing to do is buy a kirban regulator and throw the Holley POS out the door, it'll work for the time being though. The Holley TB should clear the fuel crossover, so they say, never know with them people. If it doesn't just bend the linkage out enough to clear without any chances it will hang. Did that with mine over 2 years ago and have't had any issues.
Axle/Gears: G92
Car: 1989 IROC-Z
The Holley unit isn't very good, I've heard of many failures within a year, some right out of the box. I still have the original adjustable on mine, so I don't have any complaints. This link will give some good opinions on the Holley and Kirban
https://www.thirdgen.org/forums/alte...-pressure.html . https://secure.mysuperpageshosting.c...turboregal.htm Kirbans Site
The Holley regulator is actually a stock T-Type/ Grand National regulator, 3.8 turbo, whatever you wanna call it lol. Last I checked they were $60, Kirban part# 6547 $105. Im not sure how much the Holley AFPR for the SR is, but you can bet its around the same price as the Kirban.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Just grind some off the fitting for linkage clearance
Car: 1989 IROC-Z
LOL that works too, I never thought of that (duh!!), good tip! David, have you considered a way of getting the fuel from the stock hard lines to the SR fuel rails? Just want to make sure you know the ins and out of the swap so you can do it as fast and safe as possible.
Axle/Gears: G92
![lol](https://www.thirdgen.org/forums/images/smilies/lol.gif)
what does that not work?
![huh](https://www.thirdgen.org/forums/images/smilies/huh.gif)
also No I haven't got that far into it yet? how to do you get them from the hard lines to the fuel rails?
Axle/Gears: G92
http://www.holley.com/534-192.asp
is this the fuel rail kit I need? I am going to vortec route
also is this the same one? It doesn't say vortec but list the part number
http://www.summitracing.com/parts/HLY-534-192/
also does it matter if you buy the weiland or the holley version? they are the same port size correct?
Car: 82 Z28
Transmission: T400
All other parts interchange
Holley own Weiand and packages the Weiand intake as part of a complete Holley EFI package
with ECM / wiring / pump / etc
Axle/Gears: G92
So even though it says weiand this is the correct vortec setup I need?
Car: 82 Z28
Transmission: T400
Axle/Gears: G92
Car: 1989 IROC-Z
Don't worry about the fuel rails, the guys over at summit will get you fixed up. The stealth Ram is switching over to a Weiand brand, there will no longer be a Holley Stealth Ram. As for the rails, I'm unsure as to whether or not they will make the brand change, makes sense though.
9192camaro
16
02-03-2019 12:21 AM
L98GTA87
08-11-2015 06:55 PM
