HSR:Swap from large-cap to small-cap distributor-WHERE/How did you mount the coil?
Car: 1985 Chevy Camaro Z28
Engine: 5.0 LG4
Please share your experience...pics? THANKS!
Car: 85 monte ss
Engine: 331 twin turbo
Axle/Gears: 3.73 posi 7.5"
Re: HSR:Swap from large-cap to small-cap distributor-WHERE/How did you mount the coil
http://cgi.ebay.com/ebaymotors/87-92...Q5fAccessories
this bolts to the last 2 bolt holes in the intake on the passanger side by the distributor. the coil slides between the thin sandwich and 2 long small screws and bolts hold in place. i found the stock style bracket always works best.
Car: '89 IROC-Z
Engine: LSx
Here is what I did...
I used that bracket TTmonte showed you which you should have if you swapped from TPI, I mounted the coil sideways on it and used the nut/bolt from that support brace, but you need to use a lock washer other wise it will loosen up. If you have any questions about it pm me.
Car: 85 monte ss
yeah. i never thought of that. i had my set up in a mazda RX7 so i mounted mine on the firewall also.
Engine: 5.0 LG4
So which bracket are you referring to IrocZ??? You mentioned that I should have it already. I am swapping from the original 1986 TPI.
Please let me know. Thank you again guys!
1 Post
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
i flipped my stock bracket from my coil and mounted it right on my valve cover. like it says not my favorit but works quite well.
camarostealth.jpg?t=1296974495
Engine: 5.0 LG4
I ended up mounting on the sheet metal over the firewall, as a lot of other guys have, under one of the bracket bolts on the passenger side.
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
