Stealth Ram EFI for MY setup? help needed...
1 Post
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
http://www.summitracing.com/parts/WND-7540/
so...if i was to get this, can i run my car with JUST this upgrade?
info on the car...
5.7 TPI
1 3/4" Headers
3" exhaust dual cats
CAI
what am i look at as for gains? losses?
once thats on, then what?
will this fit under the stock hood?
yes ived used the but havent found what i wanted...
Mikey
info on the car...
5.7 TPI
1 3/4" Headers
CAI
Mikey
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
Re: Weiand Stealth Ram EFI for MY setup? help needed...
You will have to change your heads, unless you are already running vortec heads or plan to swap. The vortec style stealth ram is put under the weiand name. It's an easy install, about 3-4 hours. Save your money and get a fuel rail kit with a non-adjustable regulator, then pick up a Kirban (spelling?) regulator because the one that comes with it sucks.
1 Post
Engine: 5.7 350 TPI
fer sure..thanks guys
so vortec heads are a must?
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Nope they do make one for the standard sbc head. Also you would have to mod your hood to make it fit and even then it's really close.
Car: 1989 IROC-Z
No for the Weiand brand, but the Holley brand SR will work with your heads. They have the Weiand listed as a substitute for the 87-95 heads, retarded. http://www.summitracing.com/parts/HLY-7540, this is what your looking for.
Car: Trans Am, Corvette
Engine: LB9, LT1
Transmission: 700R4, 4L60
Axle/Gears: 373, 259
Yes it will work.
Search Holley Stealth Ram.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Did you read the link I posted above on WHAT IS NEEDED for HSR install?????
You already have a computer/wiring / TB / injectors /etc
You only need the intake and fuel rails.
http://www.summitracing.com/parts/HLY-534-185/
Plenty of good deals 2nd hand
http://www.camaroz28.com/forums/showthread.php?t=782867
1 Post
Engine: 5.7 350 TPI
but dont i need the vortec heads for just base and plenum?
There is a stealth ram base and plenum kit for less than 400 bucks that will fit your L98 heads. Then need fuel rail kit for 200 more. Fuel lines to connect to hardlines custom made for 120 bucks or less in parts. That's it really.
Search for My holley stealth ram swap. I had a detailed swap thread with results on stock L98. Basically with exhaust headers 2800 stall and sticky tires I went 13.63 at 97 on stock TPI. Intake swap to hsr with drag wheels for less weight it went 13.2s at 101 in similar air. 1.6 rockers and pulleys with better air conditions I went 12.95 at 103.8
1 Post
Engine: 5.7 350 TPI
sick..always loved ur builds..gona find it now
Car: 1989 IROC-Z
Re: Stealth Ram EFI for MY setup? help needed...
I didn't notice the link I posted shows summits out of stock right now lol. Thats the right part number though. By the time your ready to do it they should have more in.
Car: 1989 IROC-Z
Look in the classifieds here and see what you can get. Might get a good deal on a complete swap. ezip has one up for sale, you don't need all of the parts he's selling, so see what he will take for the HSR, Kirban and Fuel Lines. $400 would be a fair price, but as always start low!
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Hey ItsMikey! Remember you can't pass smog with the Stealth Ram in California.
1 Post
Engine: 5.7 350 TPI
1 Post
Engine: 5.7 350 TPI
totallyconfused -_-
yes or no...
do i need vortec heads for this setup?
the link posted above to Summit says that the HSR IS this and that it just got renamed...
yes or no...
Car: 89 GTA
totallyconfused -_-
yes or no...
yes or no...
1 Post
Engine: 5.7 350 TPI
so this is definitely what i want right? with the fuel rails as well...
Try this one...................... http://www.summitracing.com/parts/HLY-7540/
The Weiand is for the Vortec heads. You can find Weiand products on the Holley web site. They must be part of the same company or they have merge together.
Car: 1989 IROC-Z
Holley owns Weiand, they put the vortec under that name to avoid confusion
Car: 89 GTA
Car: 1989 IROC-Z
That would explain why they list the Weiand as a substitute. Just make sure its for standard port heads
1 Post
Engine: 5.7 350 TPI
thats what im saying, the HSR isnt the HSR anymore...its the WSR -_- lol so i want the WND-7540 that i posted above? cuz theres another one that seems to be for the vortec setup
vortec stuff is FAR different than your factory L98 heads. You dont have vortec heads so you dont need anything vortec. If you want the stealth ram for your heads or any other aftermarket head thats NOT a vortec then go with the part number above... 7540
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, LT1
Transmission: TKX, 4L60E
Axle/Gears: 3.42, 3.23
Head spinning on this one!
-- Joe
-- Joe
1 Post
Engine: 5.7 350 TPI
^^^ me too -_-
lol..7540 is what i want tho
thanks guys
thanks guys
Car: 1989 IROC-Z
WND-7540 for 55-86 heads, WND-7542 for Vortec Heads and I don't see a number for 87-95 heads, but the WND-7540 fits 87-95 aluminum heads (info from Holleys site). Is there a difference between 87-95 iron and aluminum heads that I'm not aware of? I contacted holley to see why they changed the brand, I know they filed for Chapter 11 protection 1 year ago, but who knows. Too bad they didn't design an egr in it with the name change, that would be sweet! They're also $15 more than when I bought mine.
1 Post
Engine: 5.7 350 TPI
i dont think there was a difference. i could be wrong tho...guess we'll see
Engine: LC9, LT1
-- Joe
Car: 1988 Chevrolet Camaro IROC-Z
Engine: L98 350 TPI
Axle/Gears: 2.77 posi
If I'm already EFI do I need to get the fuel rail with this manifold?
