The use of Carb Spacers on Single Plane EFI setups.
Car: 1995 Chevy Caprice 9C1, Police Pack
Engine: 350 ci, LT1
Transmission: 4L60E. S10 TC
Axle/Gears: 8.5" corporate w/3.73 w/TruTrack LS
Is there any value in using a carb spacer a carb style single plane port EFI intake? Particularly when using with a 4 barrel TB? You know the popular ones like the the "Super Sucker" and the 1" to 3" phenolic plastic ones. Some with four holes under the TB openings or some just open space.
I know they suppose to aid in increasing the air velocity and increase the vacuum signal in carb applications but would they help us in port EFI applications??
I think of using them on a carb style single plane on intake a 396 cu LT1.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: The use of Carb Spacers on Single Plane EFI setups.
Only to increase plenum volume ( open spacer).
Car: 86 Corvette 383
Engine: 383 LPE build
Transmission: 4+3... T56 soon enough
Axle/Gears: 3.07
The single plane EFI plenum is below (and above depending on the conversion) the spacer so it would not function to increase runner length.
Unless you are running a 4 barrel EFI throttle body directly where the carb would mount, I would just use the correct open spacer.
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
If you can fit one, use it. Single plane manifolds tend to have smaller plenum area. The spacer helps this. I was able to get a 1" under my Edl Victor EFI.
