Couple pics form HSR install
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
Just thought I would post a couple pictures. Hoping to fire it up soon. Waiting for one last Summit order to arrive.
Car: Formula 350
Re: Couple pics form HSR install
Does looks slick... Can't beat the polished looks with a clean engine bay. Way to go... Should be pretty quick too.
Also, What did you use to mount your TV/Thottle/Cruise Cable? Does that come with the Stealthram or is it custom made? Looks good!
Engine: 350 HSR
It's all made by Lokar. My car was a TBI car so I didn't have the correct cables and bracket for the HSR. I hope these work out ok.
Car: 1985 Berlinetta
Engine: Mild 350ci
Transmission: TH-700R4, TCI guts
Axle/Gears: 3.23, One wheel wonder
Love the HSR! Very clean engine compartment also. You've got a nice looking setup there. -Darkwind
its alil too clean lol... thats not a stock wiring harness for sure. prob painless right?
also how much clearance u have with the kirban fuel pressure regulator and the distributer? im running mine the same way but i dont have it together. pics of the fuel lines?
looks good tho
looks good tho
Engine: 350 HSR
I'll get some more pictures. I'm running the commander 950 so the harness came from holley. But, I cut and soldered alot of it to make it look a little better. There seems to be plenty of room for the distributer and the regulator. The distributor is clear to turn. I'm nearly ready to try to start soon, but this EFI will be all new to me. I may be crying for a carb back
looks good tho
looks good tho
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
http://www.summitracing.com/parts/HLY-91506211/
Also, what Lokar parts did you use to setup the throttle controls?
Engine: 350 HSR
Did you install one of the HSR MPFI kits? This is the kit I'm contemplating using:
still no pics of the fuel lines?!? lol.
also what upper radiator hose is that? i need to get one but i have the recomended mr gasket water neck. i always wanted a steel one with 2 rubber seals at the ends to seat it and absorb the engine twist/vibrations. just curious on yours... part # and whered ya get it.
Engine: 350 HSR
my altinator is on the pass side so i dont have the interferrence that u had... and i have no AC or smog. wat was the part number and whered ya get the old one that busted. anyone kno the dayco one thats recomended for the HSR swap with a stock radiator?
Engine: 350 HSR
https://www.thirdgen.org/forums/alte...wap-upper.html
https://www.thirdgen.org/forums/alte...using-hsr.html
https://www.thirdgen.org/forums/alte...tealthram.html
Engine: 350 HSR
i just ordered my rotating assembly and my blocks at the machine shop... so now im getting serious with the HSR and figurin the stuff out.
i got 2 questions, thank you for posting the fuel lines. im gona be running rubber lines to hard lines that i bent and tran down the tranny tunnel but i wanted to see how u did urs. looks good. wat size AN lines are those?
first question. i see u mounted ur coil on the firewall. i didnt realize the stock remote mount coil from my stock 350tpi wont work untill about 20min ago!!! the bracket that bolts to the stock TPI base (last 2 bolts towards the rear of the engine on pass side) the HSR has a huge bump between the 2 bolt holes. D@MNNNN!! my question is... ive read that the coil shouldnt be farther than 12" from the distributer... and urs seems to be farther. i really didnt want to run the coil on the firewall. are u having any ignition probs?
second question. are you running a MAP sensor? my stock MAP sensor has a 2 weather pack connector and 2 vacume lines that go to the underneith side of the TB and the other i believe goes to the EGR valve. im not running the EGR anymore so do i still need to run the MAP? can i delete the MAP and be ok? seems like u dont have one so im asking u
Engine: 350 HSR
-6
None so far. I didn't want to mount it so far away, but there isn't much room up there. Lots of cars run them a considerable distance from the dizzy. I have also seen the coil mounted in the heater blower area. With air I didn't have the room
I am running a Map sensor. It has one vacuum line. It came with the HSR/commander kit.
-6
Engine: 350 HSR
For my guage it's the white wire in the 2 wire connector going to the distributor. For the computer it's the yellow wire in the other connector. I'm using a commander 950 for the ECU though. I'm not sure of the wire color for the computer on the stock ECU
yea thats what i figured... i think i can just delete the 2 vacume lines coming out of the firewall.
that MAP sensor with the one line... where is that line connected to? the TB? my MAP has 2 hard lines and i believe one goes to the EGR and i kno the other one went to the bottom of the TB underneath it, and has a Y in it which breaks off to the charcol canister which i deleted as well.
Engine: 350 HSR
The upper manifold will be installed next. There is a 3/8-18 NPT hole on the underside of the upper manifold that needs to be plugged if it is not used. Do this before the manifold is installed. There is a plug included. There are two 3/8-18 NPT and two 1/8-27 NPT holes in the rear of the manifold. The two 1/8-27 NPT should be used for the MAP sensor and the fuel pressure regulator reference hose. Barbed fittings are included for this. The one 3/8-18 NPT fitting is used for the manifold air temperature sensor (gray/white connector). The other 3/8-18 NPT hole can be used for power brakes and other accessories. There is a 3/8-18 NPT plug included, if this hole is not needed. These fittings can be installed now or later.
Car: 1987 Trans Am
Engine: LQ9/L92
That is a beautiful looking engine bay. Good job keeping it clean and keeping the wires outta sight as much as possible.
Car: Corvette
Engine: 388 HSR custom Cam see sig
Axle/Gears: D44 3:45
Sweet!
I'm doing a similar type of conversion. Going from TBI to HSR as well. This is on a vette though.
Did you do a write up at all on your conversion?
I have to get a small cap HEI distributor to replace the HEI distributor that I have. Which did you go with?
Any diagram of where you connected all your vac lines?
I know i got a lot of questions, just trying to get prepped before i make my change. The only big differance is I'm going to use ebl/flash to control my HSR
from the install manual:
Engine: 350 HSR
Sweet!
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
That is a very awesome engine bay,,, very clean,, no messing wires running all over the place like my car. Great job, I wish my engine bay looked that good.
Car: 1991 Trans Am
Everything looks great. Nicely thought out and very well executed. You said you had planned on just using a stock TPI intake path, what about going aftermarket? Get yourself a coolant overflow tank from a 4th gen so you can get rid of the crappy looking stock tank. If you want, get a 4th gen washer fluid tank and then build a cold air setup similar to what the lt1 cars use that puts the filter over in front of the drivers tire. Should work MUCH better than the TPI setup and look much better as well.
Engine: 350 HSR
Car: 1991 Trans Am
The lt1 style intake path has supported a LOT of power in the 4th gen cars and the tanks really help clean up the engine bay a lot. They aren't exactly bolt in jobs (especially the washer fluid tank) but are well worth the effort IMO.
Car: Faster
Engine: Than
Transmission: You!
I've corrected the air-flow constrictions over the radiator. Click link..
http://https://www.thirdgen.org/foru...pi-camaro.html
Car: 1985 Chevy Camaro Z28
Engine: 5.0 LG4
Pondriver, can you please tell me what type of brackets you used to mount your remote coil?
1.) Very clean engine bay.
2.) Very beautiful work done.
3.) The HSR really does look perfect as a replacement for our 3rd Gen's.
4.) This makes my soon to be HSR install that more anticipated!
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
are all of your fuel lines those stainless steel looking hoses? where did you get them??
#42
Engine: 350 HSR
Fuel lines were cut under floor pans. Compression fittings to stainless fuel line purchased from local industrial supply house. Pic shows where lines were connected under floor pan
#43
1 Post
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
B.E.A.UTEFULL. makes me want to go polished. wish i could of took more time on my swap. but i love it.
#44
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
Looks great. Seeing yours makes me want to polish mine now. My HSR, not my other thing,, you sickos. lol
84z96L31vortec
08-10-2015 08:27 PM
