9900-171 Holley throttle body help....
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Re: 9900-171 Holley throttle body help....
Finally got through to Holley and here is what we got:
TPS tested out at 4.90 volts which is approx. 5 volt reference that I needed so TPS has the supplied voltage....voltage on idle is .60 with a 1.71 WOT voltage. TPS sounds like it is bad...what do y'all think?
IAC - Found out that the harness that I bought for the throttle body is wired wrong.
GM style:
A - IAC A Hi
B - IAC A Low
C - IAC B Hi
D - IAC B Low
Holley's IAC:
A - IAC A Low
B - IAC B Hi
C - IAC B Low
D - IAC A Hi
So, IAC needs to be re-wired correctly and hopefully will fix the idling high issue.
But what about the TPS....is that acceptable or do I need a new one?
GM style:
A - IAC A Hi
B - IAC A Low
C - IAC B Hi
D - IAC B Low
Holley's IAC:
A - IAC A Low
B - IAC B Hi
C - IAC B Low
D - IAC A Hi
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Re-pinned the IAC and idle is a lot better; however, the IAC still doesn't respond when starting to help the engine start. However, it idles fine but give it any gas and the IAC just takes off and doesn't stop....what's going on here?
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Ok mods...you can delete this thread....I figured it out on my own...thanks.
Terrell351
06-13-2021 01:13 PM
mdtoren
08-16-2015 05:45 PM
