Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
lt1 intake, and port size
Old 06-04-2009 | 03:28 PM
devilfish's Avatar
Im about to isntall my converted lt1 intake to my canfield 197cc heads.
Im using the felpro 1205 gasget.
The gasget fits good on the heads, but on the intake, the ports seems a bit to smal ( se pic ).
Will this cause any driveability or other issues?
Or is it important to machine the ports on the intake, to macth the felpro1205?
intake
Heads
Old 06-04-2009 | 08:33 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Re: lt1 intake, and port size
Im not sure how far up the runner you would want to open up, but theoretically, an ideal intake path consistantly narrows as it approaches the valve. Matching the intake to the gasket will just end up creating a larger cross section about halfway down the tract, which will probably just stall the incoming air anyway. I wouldnt bother. As is, it wont cause any driveability issues, and is quite a bit of work for zero gain.
LT1Formula
20
11-14-2015 01:02 AM
toronto formula
11-10-2015 07:17 AM
86White_T/A305
08-17-2015 01:16 AM
Jake_92RS
08-11-2015 11:39 AM
knight72
08-10-2015 10:32 PM
