FIRST injection or HSR
Engine: 5.7 vortec crate w/TPI
Transmission: 2004r
I was pretty much set on getting a HSR this winter, but now that the price has gone down on the FIRST injection setup, I’m considering that as well.
Here’s what I’m trying to decide:
My motor is the GM 350 HO that is claimed to make 330 HP at 5000 RPM and 380 ft/lbs at 3800 RPMs with a 600 cfm Holley:
http://store.summitracing.com/partde...8&autoview=sku
The motor is currently making peak HP at around 4200 RPMs, and falling flat after that with a stock TPI setup. I'd like to make peak power about 5000 or so, and it seems like both the FIRST and HSR would be able to achieve that goal.
I'd lose a little torque down low with the HSR from what I've read, but I'll have a much better powerband above 3000 or so, and as I'm planning on running a roughly 2400 9.5" stall I wasn't too worried about that "loss", especially since it seems like the car will be easier to launch.
It looks like I'd be able to be out the door with a complete HSR setup for about $700 including misc fittings, extra braided fuel line, etc.
Now this comes along for only $150 or so more, and I'm wondering it if would suit my motor better, as it seems like I'll be able to hit my HP peak at 5000 without the loss of torque down low.
So, what would you guys pick? HSR or FIRST? Is the FIRST setup work the extra money?
Re: FIRST injection or HSR
BadSS has some good posts comparing the FIRST to the HSR. He has run both. check out this thread:
https://www.thirdgen.org/forums/alte...ighlight=badss
Transmission: 2004r
Thanks for the link! I was actually reading that earlier today and I gave FIRST a call a little while ago...just waiting for a call back from them on a few questions I have.
From what I've read so far it looks like I'll be getting a FIRST setup instead of the HSR, but I figured that it wouldn't hurt to ask for opinions on here as I won't be able to buy anything until I get my paycheck on the 31st.
The HSR typically shows gains above 4,000rpm over a LTR setup. The First flows a ton better than any other LTR setup out there, but the HSR will still put out more power up top. You won't have the same grunt down low though as a LTR would. Say when you are in overdrive on the highway and just want a little omph for a pass, the LTR setup will feel stronger than a HSR would.
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
I have the HSR but am switching the the FIRST, more for the EGR then anything else, but the added mid range will be nice
HSR plus a 52mm TB is basicaly same price as a FIRST which comes with its own TB
http://www.firstfuelinjection.com/products.htm
The FIRST® Manifold does have EGR provisions.
Ninja, it sounds like the FIRST would fit better with what you're looking for. The HSR isn't bad at all,,, it makes power a lot like a dual plane carb intake down low and close to a single plane intake up high,, so it is no slouch,, you just don't get the midrange torque boost from the FIRST's long tubed runners. I'd expect you to run similar ETs with either intake,,, you'll just shift the FIRST a lot sooner compared to the HSR,, maybe 5500 vs 6100 with your combination.
Car: 92 Camaro Z28
Engine: 383
Axle/Gears: 9"
anyone know what the cfm is on the FIRST? or how well it distributes forced induction air and holds boost pressure?
Transmission: 2004r
I picked up close to .5 seconds ET with the FIRST compared to a fully ported TPI and hogged out SLPs (as much as you can without cutting and welding),, so I'd say it's a good bit better than the typical "modified TPI",, even though it is a TPI (lol).
I figured that since my motor wasn't really built to rev above 5500-6000, the FIRST would work well for me.
Plus, I'm a sucker for that LTR look.
I actually ordered it yesterday, and Ken from FIRST told me to expect it in sometime next week.
Car: 1989 Iroc-Z
Engine: 383 FFI
Transmission: TKO600
He made the right choice. For the RPM he wants, the FIRST will give him more than enough breath up high, without the loss of that magic down low torque.
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I was talking with them last week thinking I was going to jump in on the GP but what he told me was the average total flow there getting through the runners and base was around 232 cfm.
only 232cfm ouch!. glad i went with the HSR, HSR flows sumthing like 275 i think. and its easy to get the midrange tq outa the HSR... u just build a 383
i had a hogged out TPI, ported plenum, portmatched to SLPs, ported base etc.... took it to the track and hated it. cant get it to hook. too much unusable tq in the lower RPM ranges. on the street its fun dont get me wrong but too much of the throttle and my @ss end goes everywhere. the HSR would help by creating the tq higher in the band.
try to go up against a LS1 etc and watch them pull away with the top end they have. do have to say the FIRST is a nice system tho hope it works out well for u.
I dont know about those flow numbers
First base alone flows 300 and has be documented by members here
What exactly is your motor combo Ninja? From the sound of it, if your looking to peak at 5000 rpm and shift alittle after, the First is far better choice just because it will have more torque than HSR and make same power.
If you were looking to peak at 5500 then I'd go HSR all the way. HSR is VERY strong after 5000 rpm all the way to 6500+
Transmission: 2004r
I have the 350 HO "deluxe" crate motor listed in the first post.
You cant go wrong with either setup as both will probly end up making same hp numbers... its just that the TPI setup will make more torque. HSR will have a flatter curve which has its advantages too. 2400 stall speed is a great speed for a street car with that motor.
If you dont plan on upgrading cam/heads for more rpm/power later on, then go FIRST TPI. If you do plan on doing things later on, then go HSR.
I do admit I like my HSR, but there illegal here and the FIRST isnt, so FIRST I go
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
-- Joe
I feel a heavy monte with automatic transmission can profit in driving pleasure from the FIRST setup. I do like the HSR too, and obviously it's a close call between the two.
first looks like it ATE the D@MN box it came in lol like a juiced out TPI and it looks goofy and chubby compared to the TPI/HSR.doest really have the hard lines anymore. hsr is just preeeettttyyyyy! and simple. hey who wants to take out 18bolts to get the runners off lol. and the large monoblade TB looks like a catfish's mouth... end of story
Car: 1989 Iroc-Z
Engine: 383 FFI
I still have my AIR, Canister and Cat's, just need the EGR, it never used to be that bad, this just started in the past few years, I guess they ran out of bank robbers and murderers to catch
lol LMskyliner im just messin. its not to bad... i dont like the lines of the First... it does seem very "bloated to me. but its still not that bad looking... i remember the ones with the TB mounted to the side and it looks like the First was taking over by the grudge girl. lol.
hawk92z-TDZ! do it!!! i would love to see the beatdown. the road inspections are the same in NJ.... they tow the car on the spot and u have to pay the tickey/towing/ and impound. its ridiculous... my solution is to build it fast enough so they dont see me or practice my Kturns at higher speeds to take different routes lol
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
you all are talking about flow...with the heads this guy is running he'd be lucky if they flowed 210 cfm on the intake side....soo no matter what he goes with its not gonna choke it out...as far as the stealth ram goes...i love mine, but im not sure if id like it on a basically stock engine
While that is true, either intake will provide significant gains as the stock TPI is a big restriction in an of itself.
You could also argue that because of the stock head flow on TPI cars that going with headers and a cat-back is a waste as well, however we all know that headers and a catback will give a significant gain on an L98 or LB9.
In a perfect world we'd simply rebuild the entire engine from the ground up in one shot, however we don't live in a perfect world with plentiful wallets so we do it a piece at a time. And either of these intakes will be a significant gain towards future mods.
Car: 92 rs
Transmission: 4L80E
I was talking about the intake flow not choking out the heads...anything is an improvement over stock. OR89rocz..I was curious if those time were ran at pitts internatonal raceway. Thats the closest track to me, if i could keep a tranny in my car longer than 2 days ill come play....
u might lose alil velocity with the larger port first/HSR intakes but then again the vortecs arent a shabby head. they can make 400-430hp pretty easily. over a stock head u can see 50hp even with a stock TPI. i saw a build with stock 87L98 stock cam, hp went from 225 to 305 with a head/vortec high flow base, that power then jumped to 355hp/423tq with edelbrock runners, 52mm TB, and the GM hot cam. (plenum remained unported) and this was with a stock 87 L98 chip. (the vortec heads were modified for larger valves/higher lift by scoggin dickey) so thats why they were able to use the hot cams lift. thats not a shabby TPI motor by any means.
i think the first/HSR would fit nicely on vortec heads flow. and would also allow enough flow for larger heads like 195-215cc.
the 2 intakes will def create different hp/tq curves. i would go with the HSR bc it allows u to launch the car harder due to lower HP/tq in the lower RPM ranges. Thats my biggest prob with my modded TPI is that i cant get the wheels to stick with the TPI tq. and the HSR will allow u to run with the LT1 and LS1 in there powerbands. so u dont get killed at the topend.
Car: 91 Z28
Engine: LB9
Transmission: 5 speed
Axle/Gears: 3.73 limited slip stock
If i felt like it, LMSkyliner was thinking of letting me borrow his First TPI and placing it on my 400 turbo motor. I'll be breaking it in on motor and could do a dyno comparison possibly between HSR and First. Motor is nothing special tho, just a 9 to 1 aluminum head 400 with a mild 233/233 cam. I wouldnt expect this to be a great test for showing the limits of each Intake.
I wont test it on boost tho. Once the turbos are on and plumbed, i'm not changing a thing
i dunno, its winter here right now, brrrrrrrr
I have both intakes here, HSR is still on the car , but my 6-speed is a 5-speed right now, 4th gear is missing, and thats what I need for the dyno so I gotta get that fixed first.
Basicaly dont hold your breath, prolly wont have both dyno'd and posted till later in the year, I was hoping to grab the Mini Ram to add to the comparisons since I need it for my 421ci build anyway's, but the times are slow so I am thinking of hold back abit on that.
I couldn't use the first. No distributor cover. Just seems like it was forgotten. Seems kinda ghetto. I know some of you don't care, and that's cool. ...but for such a little amount of extra work, you'd think they coulda done it for us "appearance also" guys. Heck you can paint or polish it??????
