Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
miniram compared to tpi @ track
Old 11-02-2008 | 06:31 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
Friday was pretty much the last day the track was open, so i made up a rudimentary tune and went. My previous best with tpi was a 12.27 at 106. with the intake as the only change it went 11.95 @ 114. 60' fell from 1.56 to 1.59, but from there on i was very impressed with the power. mods are in sig, and all this is on the original bottom end. im sure there is more in it as i never changed the governor springs in my trans and it was shifting at 5700 rather then 6000 like i would want. im sure with a better tune and shift points an 11.80 @116 would be possible. but the miniram did give me 8 mph.
Old 11-02-2008 | 06:57 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: miniram compared to tpi @ track
wow! nice pickup!
276hr14
that cam is on a 114 lsa right? looking at hr14 that is, as most 110's comp has are hr10 and the 112's go hr12.
Tighten that cam up on a 110 and you'll gain even more! 110 isnt that tight for that duration, it will love that on the miniram
nice times
Old 11-03-2008 | 12:41 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula, '95 Formula
Engine: LC9 , LT1
Transmission: TKX , 4L60E
Axle/Gears: 3.50 9" , 3.23 10bolt
Glad to see you put my old miniram to good use!
I'm looking over your bin. Just been busy with the house. I'll get back to you soon.
Good luck with the car. Sounds like a demon!
-- Joe
Old 11-03-2008 | 01:34 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Those are great times. Gives me hope for my combination.
Old 11-03-2008 | 01:40 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
-- Joe
i used the bin i sent you. i made it run in open loop all the time to get rid of the popping. its actually a little rich, and i added a bit too much ae to it. im going to get a wideband and put it on a dyno, but i was in such a hurry to get everything together before the season was over that i had to guess at it. id say my guess was pretty good!
Old 11-04-2008 | 08:19 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Very nice times can't wait to get my AFR heads on!!
That's quite the gain in MPH from the stock intake, wonder how a aftermarket longtube intake would compare.
Old 11-05-2008 | 03:08 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Read the sticky post in the TPI forum "Quest for a better flowing TPI" and you'll see my results from a three different TPI swaps.
Congrats Matt on the huge gains!
Old 11-05-2008 | 07:01 AM
anesthes's Avatar
Engine: LC9 , LT1
Probably close ET.. Not as much MPH.
I spent a TON of time and money on a ported base, SLP runners fully ported, plenum, siamesing and all that.. With ONLY a swap to a singleplane intake it picked up 10mph..
That's not to say you cannot make power with the other combo - it was still fast, it will just never be as fast as a high flowing short runner intake.
-- Joe
Old 11-05-2008 | 07:44 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Can you post up the whole slip from 60 foot to 330 to 1/8 mile to 1000 ft and 1/4?
i want to see how it all looks throughout the run
Old 11-05-2008 | 08:12 AM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
when i get home tonight ill post the slip up
Old 12-02-2008 | 09:50 AM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
any luck on posting that timeslip? This thread has made me interested as I have the same combo, but need acam.
Old 04-05-2012 | 04:42 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Yea I'm bringing this up from the dead. GTA Matt, did you ever get the car dynoed? Any new times?
Old 04-05-2012 | 07:22 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
Wow, forgot about this one. Digging around my old photobucket I found a few pics of some slips. Alot of them seem to be from the summer of '09. I have a pretty good memory when it comes to these things tho, so I'll go over it some. I went the 11.95 @ 114 in VERY good air obviously in early november. The following summer it was going consistent 12.0's @110-112. Never dyno'd it or even nailed down a good tune before I switched to the 110 LSA cam I have now. The results of that are documented here, but I gained 2 mph I believe, back near 114 in summer air. I went thru 4 ring gears in 21 days and ended up changing the timing curve to come in REAL slow. This slowed the 60' a bit and I also think it has some effect on the severe bog I was getting on the 2-3 shift. I never really nailed it down, only worked on making it consistent for bracket racing. Best pass it has seen, and I have no idea where the slip is, was a 11.94 @113 or 114 with a 1.52 60'. The ring gear broke for the last time the very next pass and I vowed to not return with the car until I've completely redone everything exactly the way I want. Paint, cage, rear, trans, wiring, plumbing, etc. Still unsure on the powertrain, but overall, I've been impressed with what I did on a budget with the stock bottom end and 3450 pounds.
This was during the summer, bracket racing. Not even sure why I took it, but must have been some significance at the time lol.
Have no idea here either, but a .003 bulb, 1.59 60' and 11.96 @113.8
This was bracket racing during the hot/humid summer. I remember this one. When I finally nailed down some consistency.
I think these were the first passes with the new cam. Old cam time slip from the week prior 1/8th mile race to compare.
I think that covers it lol
Old 04-06-2012 | 02:40 PM
thegooseman's Avatar
Car: 1992 RS
I may have missed it, but what stall are you running?
Old 04-06-2012 | 04:16 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
Its a vig. Supposed to be 3500 but its very tight. Only footbrakes to 1800. Flashes just a bit higher.
Old 04-07-2012 | 08:13 AM
88BlackZ-51's Avatar
not suprised. i do think the miniram is the best all around intake for motors anywhere from 350-450 cubes for making power.....
this is a general statement. not best for all combo's but most.
seems like you picked up around 100 hp. lol.
Azrael91966669
25
06-20-2017 05:04 AM
Caspar
06-20-2016 12:19 AM
LT1Formula
20
11-14-2015 01:02 AM
86White_T/A305
08-17-2015 01:16 AM
Sanjay
08-12-2015 04:41 PM
