I miss singleplane intakes.
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, LT1
Transmission: TKX, 4L60E
Axle/Gears: 3.42, 3.23
So I'm building another setup. Be about a 110* intake elbow to an ls1 throttle body when done.
The stock height of the 9901-101-1 Holley manifold is 5.65". We milled it down to 4.125".
The elbow will be 4.75" on the hood centerline. This will fit under the stock C4 hood.
cardboard mockup of the 4150 to LS1 throttle body adapter.
Throttle body is up-side-down in this application (2 bolts top, 1 bottom).
I sold my Miniram to GTA MATT. I imagine he will chime in soon as he progresses with the install.
-- Joe
-- Joe
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
Engine: LC9, LT1
Re: I miss singleplane intakes.
http://intakeelbows.com/ if time is more important
I can't weld aluminum, don't have a metal brake, etc.
-- Joe
Did you see Edelbrock is now offering 5 different intake plenum elbows in various height and sizes? Adapts to a front mount round TB and a 4150 square bore intake mount pad. Seems to be what a C4 owner would want with a single plane intake!
Engine: LC9, LT1
My elbow is on a UPS truck, aaron got it finished early. Hopefully it fits on the first try.
-- Joe
I enjoy following your work here, since it is similar to mine. Although you seem to have a jump on me with already owning the blower.
Please post some pics of the elbow when you get it. I'd like to see the differences internally between a fabed one and a cast piece. Hopefully it fits right for you the first time.
How are you doing your tuning?
Engine: LC9, LT1
-- Joe
Quote: The stock height of the 9901-101-1 Holley manifold is 5.65". We milled it down to 4.125".
The elbow will be 4.75" on the hood centerline. This will fit under the stock C4hood.
I am interested in doing a swap to Port EFI possibly next spring(EBL-ECU). Will ditch the TBI manifold and may attempt to use my existing 7.4L TB to start until I can save the $ to buy an edelbrock sequential TB. I currently have a low profile procharger bonnet on TB.
Question why did you select the Holley unit? I most likely will use a Victor as I believe it will clear my C4 hood. My Holley TBI manifold is 5.4 inch high. Vic is 4.58. Plus I no longer need the 1.0 spacer to clear the injector pod. Not sure what other options I have? Professional Products? Thanks!
Engine: LC9, LT1
If you go with a forward mount box, you should be able to use the victor. The victor I think is 4.5" tall, the low-profile forward mount LS1 throttle body should clear the hood but you may need a water neck adapter.
Professional products is almost 6" tall. I spoke with them, and it cannot be milled down because it's got raised runners.
Snap me some pics of your setup. I'd love to see it.
-- Joe
Car: 79 Monte Carlo
Engine: 406
Transmission: 2004-R
Axle/Gears: Phord 9 inch/3.90
Nicely packaged. Very well done.
Question though- Would you still have used the elbow instead of a regular 4 barrel throttle body if hood clearance wasnt an issue?
Engine: LC9, LT1
The first one I did had a 70MM monoblade and it drove great, and trapped 119-120mph in the 1/4.
I also have this theory that on a turtle shell manifold like this, running the plumbing the way I did (real slow long curve) is much better than a "hat".
Maybe I'm wrong? This whole setup cost $1,100.
My other setups:
http://members.cisdi.com/~anesthes/intake-8-27.jpg
^^ 4bbl I built in 2005
http://members.cisdi.com/~anesthes/p...e/racetime.jpg
^^ Monoblade I did in 2004.
-- Joe
Car: 79 Monte Carlo
Engine: 406
Excellent info, thanks.
I might be a little confused though, so could you clarify quick?
If this was an N/A deal and hood clearance wasnt an issue, do you feel a 4 barrel throttle body with a standard 14" air cleaner would work well? Is the elbow just a solution for lower hood clearance?
Thank you, it looks like you've ran a couple different setups based off the single plane deal. Hard to find people like that!
Engine: LC9, LT1
I think on a naturally aspirated setup the first objective would be a plenum. I think that would also kill the 4bbl setup.
Next is heat. Unless you had an open hood, or cowl, your just drawing in hot engine heat. If I had a N/A setup, i'd plumb the air filter to the front of the car. I think the benefit of colder air outweighs the pressure drop in the length of pipe.
A few guys on here are running singleplanes and all to my knowledge have built plenums.
For a straight-out drag car, a 4bbl with an open air cleaner and hood scoop however would probably be a killer setup. Something that shifts at 7500, doesn't need much of a plenum, etc.. But I think for a 'street car' the design needs to favor where you are in the power band most of the time, and that is under 3,000 rpm..
-- Joe
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
Probably not. The last one I did (not the first one) had a 4bbl throttle body, and throttle response was horrific.
My other setups:
-- Joe
My other setups:
-- Joe
Engine: LC9, LT1
I'm glad to see you went back to a single plane, your my original reason why I went to a single plane from a Mini Ram. So when I saw that you went with Mini I was in shock especially knowing how bad they distribute air to back 4 cylinders. I don't know why you had such a bad throttle response with 4bl TB, mine is off the chain and crazy responsive. I've also trapped 122 mph with my set-up.
122mph is fast as crap with a n/a setup. Impressive!
The miniram was for hood clearance. We all make mistakes.
-- Joe
Car: 79 Monte Carlo
Engine: 406
I'd be interested to hear more about your setup too ZZ. What type of spacer is that? I currently have a Wilson 4 hole tapered spacer with my carb... maybe I could reuse that.
Been hearing some negative things about single plane EFI setups regarding reversion, so I wanna make sure I do this right the first time! BTW, I'm guessing the 122 MPH was using the Zex, not?
joe, looks good! BTW, i havent put the mini on yet. waiting for my racing schedule to clear up. i did take the time to polish it though. if i could figure out how to post pictures i would send you some. should be putting it on in a few weeks
Maybe the spacer you are running? I was running the cc-306 cam with it, no spacer, and 10:1 compression.. Your 383 with the 847 cam + spacer might be a better combo. What is the compression ratio?
-- Joe
-- Joe
Engine: LC9, LT1
Well..
This combo is deadly fast.. And, in 6th gear it will even cruise around 1200rpm.
This is all when hot. (around 180f).
However, when cold, it won't even get out of the driveway without stalling.
(oddly enough too much enrichment)
Guess we'll spend some time with the laptop tomorrow.
Problem with chasing down these gremlins is, by the time you *think* you have it figured out the car is warmed up and running fine ..
-- Joe
-- Joe
Joe,
Looks Great man!!! How close is it to the hood? How are the underhood temps with the blower and such? Or I guess what are your intake air temps?
I initially looking into a miniram when I started this project and with a bunch of guys (you included) talking about the crappy air distribution I went with a single plane. Another couple weeks and I should be out for a road test.
Again, Good job!
Again, Good job!
Car: 79 Monte Carlo
Engine: 406
Anybody look inside their single plane EFI intake after it was used? Tonight I pulled the throttle body off the above pictured setup (clean), and from the butterflies all the way down the runners are pitch black. The engine this setup was on had less cam overlap than mine does, so thats worrying.
Engine: LC9, LT1
-- Joe
Engine: LC9, LT1
Joe,
Again, Good job!
Again, Good job!
I'm seeing 160f out of the blower at around 4psi shifting at 4500. I don't want to push it much higher until I finish dialing in my tune, and potentially swap out the fuel pump.
Thanks!
Good luck with your combo. Post pix!!
-- Joe
Car: 79 Monte Carlo
Engine: 406
Good point, but not in this case. This setup was recently swapped onto the engine he was running for years. Never had a problem.
Heres the bottom of the throttle body, the inside of the intake looks the same.
Considering that nothing was sub-par on his car, it makes me worry about needing a cam swap in mine.
Engine: LC9, LT1
I'll take a peak in my intake next week after I put a couple more miles on it.
-- Joe
Engine: LC9, LT1
Good question.
According to summit, 6,000 RPM
http://store.summitracing.com/partde...5&autoview=sku
According to holley, 7,000 RPM
http://www.holley.com/9901-101-1.asp
My cam is 222/230, so I'm shifting around 5,800-6,000 RPM so it's perfect for me.. For a race motor that sees 6,800 RPM shifts probably want to go with a pro-ram in a 1206 port.
Electronics wise, it is a '730 ECM out of a 90-92 Fbody. Running a modified AXCN bin (corvette, manual trans, 1991).
-- Joe
-- Joe
Engine: LC9, LT1
Boost retard is designed for folks who can't lock in or change their total advance. I advance out to 26* and stay there.
There is no point to advancing out to a higher number when near baro, and then taking out advance as boost ramps - that method causes the cylinder temps to get hot.
-- Joe
-- Joe
Engine: LC9, LT1
What annoyed me was the fuel rail kit. They don't sell a 'complete' rail kit. I put together a shopping list of parts that I *think* would work, but never bothered purchasing and trying.
If edelbrock sold a rail kit with an AFPR and -6 ends like holley, I'd be much happier.
Another thing I took issue with was the way the rails mount to the intake with those dumb clips. But that could be just me.
I do like the new Proflo2 casting / setup:
http://www.edelbrock.com/automotive_...pf_intro.shtml
I think it's cleaner, has a better injector angle than the Victor, and it is complete. I'm curious if you can buy *just* the rail kid and base plate though. The electronics and 4bbl throttle body would not be needed for most fbody/ybody owners.
It's not a manifold for 500hp cars, but for most guys looking for HSRs or Ramjet's it's probably a good option.
-- Joe
#43
See i know edelbrock makes two victor EFI setups... based off the victor JR and victor E manifolds. Victor E says it supports hp up to 8500 rpms and i know many motors using victor jr and such doing faster times than me.
I want a manifold that will support near 7K on a 383 and will feed 550hp+ I'm close to 500 on motor now, i'm thinking of new bigger cam over winter. Not sure if teh HSR is holding me back or not but i wouldnt mind trying single planes.
Its between the victor stuff, FAST and holley. i dont mind incomplete fuel rail systems but the more complete the better. I just want the power/rpm range
That blackening of the TB looks like PCV system stuff but i cant be sure.
#44
Car: 79 Monte Carlo
Engine: 406
Dont worry about hurting my feelings here, but for what reason isnt the Accel Pro Ram intake manifold mentioned much when talking single plane EFI? It has a nice fuel rail mounting setup, and the casting is actually quite clean... even compared to what my current Edelbrock RPM air gap was prior to port matching.
I'm also curious which manifold the Pro Ram casting is based off of. Anyone know?
#45
Engine: LC9, LT1
-- Joe
-- Joe
#49
Engine: LC9, LT1
The new singleplane intake from edlelbrock (proflo2) looks pretty cool.
-- Joe
