HSR fuel rail/regulator info
Car: '00 Tahoe SS
Engine: Supercharged 5.7 Vortec
Transmission: 4L60e w/TransGo Stage 2
Axle/Gears: 10 bolt 3.73 posi
Anyone running a Stealth Ram or even thinking about it should check out Professional Products part #10608. Their fuel rail kit comes with a nice billet adjustable regulator, anodized rails and lots of fittings to set it up several different ways. The feature I like the most is the ability to run a fuel crossover through the open middle area of the Stealth Ram intake. The regulator is a really nice piece as well. If you have a supercharger it will raise fuel pressure 1:1 with a boost reference signal. I bought mine on ebay for $169 and it fits perfect on my Vortec set up. Check out the pics and let me know if you have any questions. I don't have the crossover run in the pics because I need to shorten the hose first. I really think that this is by far the best set up out there and it even ended up being the cheapest I found. I am not trying to sell their product but I just want to let everyone know how nice it is.
Their site page is http://www.professional-products.com/fuelrails.php
Car: '00 Tahoe SS
Re: HSR fuel rail/regulator info
You can plumb it several different ways but since it has holes tapped on the bottom middle of the rails I am going through the open center area of the Stealth Ram. I have to shorten the hose that came with it so I have not installed it yet. Look at the way that it runs in the photo of part #10608 at http://www.professional-products.com/fuelrails.php and you will see how I will plumb it.
Car: '00 Tahoe SS
8.75" The rails bolted on with no modifications. The kit comes with anodized spacers to match the rail. I used 1/16" of spacer between the rail and the manifold to make the rails perfectly in line with the manifold injector bosses. The injector o-rings are fully seated and I can easily twist the injectors so there is no bind on them at all.
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Man, I'm gonna have to check that out. My biggest problem with the HSR is the way the AFPR is setup with Holley's fuel rails. It's a major PITA to adjust (with it being way back there and with the adjustment screw facing the distributor). I like this setup a lot more. Only thing I don't like is the red anodizing. Maybe I could get them to custom make me a setup without it being anodized.
Car: '00 Tahoe SS
They do have other engine applications in blue, black and natural aluminum so they may be willing to do a different or no color for you. If not I've buffed off anodizing before it's not really too difficult to do. The real beauty of this kit is that you have so many options to work with. The rails are tapped at both ends and on the bottom in the middle. It comes with all types of fittings and a steel braided crossover hose. The regulator can be used as a two port or three. I plumbed mine like I did because my oem fuel lines come out between the distributer and the driver's side valve cover so I will end up with a couple of short hoses. I emailed the company with a few questions before I bought it and they replied right away which is really nice these days too.
Car: '91 Camaro Z28
Thanks for posting that info up! I'm going to be contacting them to see if they can help me out with a custom order.
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Thanks a lot. 1 more question if it's not too much trouble. The mounting hole to the bottom of the fuel rail, what's that measurement?
I'm trying to see if they will work on the Ram Jet intake. The fuel rails for that from GM are ridiculously priced. I am using some Edelbrock rails, but it's looking like these rails could also be an option, and even a complete kit. The 8.75" matches the Ram Jet intake.
Car: '00 Tahoe SS
Both rails are the same. Overall length is 11.25". Each has three holes tapped 3/8 NPT. One hole on each end and the third is on the bottom in the center. The kit comes with enough plugs and fittings to make several different configurations. If you go to their web site there are links to a couple of pdf files that show the fittings that are included and a diagram for a configuration that should work on a Ram Jet.
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Car: '00 Tahoe SS
That could be done easily with this kit but I have a supercharger mounted on the passenger side so it would not be any better for me.
Car: 1991 Trans Am
What all was included in that profesional products kit? I want to make sure there really isn't much more needed. I understand I still need to connect to the stock lines but have other plans for that.
Car: 88 IROC
Engine: 5.7 RamJet
Car: 89' IROC-Z
Engine: HSR B2L 350ci w/LT4 hotcam and AFR 195's
Transmission: Transgo'd 700R w/Yank 2800
Axle/Gears: 9 Bolt, 3.45
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
I achieved the same effect by pluging the stock APFR hole and fitting a Aeromotive 13301 reg as shown on PP rail.
NB ; is listed as a carb reg but comes with a 20-60lb spring for EFI apps
Car: 89' IROC-Z
I ordered a Kirban and I cannot install it because pointing driver side it hits my tall style valve covers (which I cannot change because stock height covers wont clear my rockers) and pointing passenger side I cannot get to the adjustment screws because they are under the distributer...
Now I need to simply plug the hole and order the aeromotive AFPR and sell the Kirban to someone with lower clearance valve covers.
My question to you is what part # did you use to plug the stock holley fuel rail hole for the AFPR?
Car: 82 Z28
Transmission: T400
Someone with access to a lathe could turn up a plug to take a O ring and hold it in place using the original fuel rail holes.
NB; I used that Aeromotive reg because it was the narrowest available from their range.
There may be others available from other makers in a similar configuration
Car: 89' IROC-Z
Yep I went to a machine shop, had them drill and tap the fuel rail and I put an Earl's 3/8 pipe fitting on it with some permatex and tightened her in.
I used an aeromotive afpr with the back hole capped with a Earl's 6AN cap.
Here is a picture of what I did. (I followed a similar setup from another TGO member)
The only difference from the picture and what I actually did was I could not use the swivel 6AN/6AN coupler pictured....It made the setup too long and smacked into the firewall...I screwed a 6AN fitting directly into the fuel rail from the AFPRand just prayed when tightened it was face up...which it was
Car: 89' IROC-Z
you can get all the parts from jegs or summit.
AEI-13109 FUEL REGULATOR
EAR-581406ERL -6 PORT PLUG
EAR-593204ERL 3/8 NPT PLUG
EAR-985006ERL x2 -6AN TO -6 O-RING
I had my rail tapped by a machine shop for the 3/8 plug and sealed it shut.
I couldnt use the coupler because it made the rail too long and the AFPR hit the firewall, the 6AN is screwed directly into the fuel rail with an 0 ring on each side.
any ? let me know
any ? let me know
9192camaro
16
02-03-2019 01:21 AM
