Weiand Stealth Ram
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Weiand Stealth Ram
Hey there
I found Weiand Stealth Ram (part no. 7540/7540P) and im a bit confused about which heads it fits ?? I have Edelbrock 60859 heads on SBC gen1 http://store.summitracing.com/partdetail.asp?autofilter=1∂=EDL%2D60859&N=700+115&autoview=sku
and was wondering if it will fit or do i have to use LTR which is not good idea for me.
Best regards
WASyL
Best regards
WASyL
Received 1,839 Likes
Re: Weiand Stealth Ram
There are 2 basic versions of the Stealth Ram; one for Vortec heads (raised intake ports), and one for all other heads.
The 60859s are in the "all other" group. So the more common SR (lower price too, I think) will fit them. No need to keep the LTR setup.
thank You very much
pzdr
pzdr
Car: 1987 iroc z
Engine: 357tpi
Transmission: t5
wasyl i have a similar setup i just have the stroker kit but i was wondering what kind of power do you get with your setup? thanks
the engine is still beeing build so the only power i have is of the wrench that i use when it will be ready i'll let u know
best regards
best regards
Car: Used to drive a camaro
WASyL, check your throttle bodies cable bracket (butterfly bracket) for interference with the driver side front fuel rail fitting. Depending on your style of throttle body, you may or may not have an issue.
still in workshop, maybe next week it'll be ready
i'm useing Holley 2x58mm Avanger TB so there is no problem with clearance
here is a pic of an engine
yes it's on the road again, just forgot to write, at the moment i'm brekeing in the engine, just 200 miles left, it runs perfect (maybe except starting at cold engine as coldstart was removed due to HSR does not have it) and it feels powerfull even thoe i'm running on stock injectors but with bigger fuel presure on them, 30 are to big for stock ECM, now im collecting money for Commander 950 to finetune it and then choose the stall converter. actually i had one race with a guy running 300hp audi s2 and it was like takieng candy from the baby i'm hopeing to see 350hp+ when everything will be set
Car: 1987 iroc z
Engine: 357tpi
Transmission: t5
sounds nice man im still tryin to get my miniram $$$ together! hopefully by the end of jan ill have it and a new cam!
what power do you expect to get ??
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
I Just noticed you have 383, in that case you would need a 36 lbs injectors. Remember when using any ford SVO style injectors always add 2 lbs to the injector flow rate all other injectors type what they flow in the injector flow rate in the constant are of the bin.
jest i know i can change bin but i do not like to play with chips, i preffer piggy-back's or SA, yes i do have SVO 30lbs, ill see will they work with my fuel, if not than i will buy something bigger
I know that chip burning can get old and annouying, so what I did was buy a NVSRAM from moates.net and now I have the same capability to reflash my ECM through my ALDL port just like the LT1/LS1 cars. But I can make changes with car running. Make sure you put 32 lbs as your injector flow rate. Just do a search for NVSRAM on DIY forum.
well i won't touch ECM, i've just finnished reading commander 950 instruction book and i've decieded not to use it, here in Poland we have piggy-back called Ecumaster (universal device) which does all the same and it is much cheaper, it cost me about 130$ + about 20$ for MAP. It has full fuel and ignition map, MAF-to-MAP conversion, launch control, street-dyno and couple others. one only thing i need to know is MAF voltage range, is it 0-1V or 0-5V ??
well i don't know 730ECM (i'm quite new to f-bodies and modding them) but Ecumaster is like C950 and can do all the same but is sold without harness and sensors. here in poland it is hard to get ECM's and geting them from states is expensive so i try to find all the ways to save some money if i can to buy things from US that i need and cannot find any counterpart here in europe
Car: 1987 iroc z
Engine: 357tpi
Transmission: t5
