will my Holley AFPR fit the HSR fuel rails
1 Post
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I have had this same Holley AFPR for about 6,7 years. Apparently, its an older type, and does not have the problems that the latest units have.
If I install an HSR, would this older Holley fit the HSR fuel rails. This Holley AFPR does fit the Chevy facory TPI fuel rail.
I assume, yes, but I want to check here.
1 Post
Car: 1991 Z-28
Engine: 350 L98 al head Stealth Ram
Axle/Gears: 3.42 LS1 brakes
Re: will my Holley AFPR fit the HSR fuel rails
No the TPI regulator is different than the Holley Stealth ram . The stealth ram uses one like Buick GN . The Kirban regulator seems to be the better choice but I 'm using the Holley adjustable one right now .
1 Post
Car: '87 IROCZ
Engine: 395 ZZ4
Thanks for the info.. So, I should buy the Holley fuel rail with the non-adjustable FPR, and than replace it with a Kirban AFPR, will that work?
I am trying to avoid the crappy Holley AFPRs. I have seen too many posts concerning the latest Holley AFPR over the last year.
1 Post
Car: 1991 Z-28
On Summit's website it's almot $50 difference for the AFPR Thats about 1/2 what the Kirban is . If I'd known before I would have got the Kirban
https://secure.mysuperpageshosting.c...com/index1.htm
