View Poll Results: Did your Holley AFPR Fail
Voters: 74. You may not vote on this poll
HSR Adjustable Fuel Pressure Regulator Failures.
#52
Re: HSR Adjustable Fuel Pressure Regulator Failures.
I see it's been a while since anyone added anything here but I just had to share. I've been chasing a horrible flooding issue since yesterday so pulled the vacuum line from the POS holley regulator and turned the key to look for fuel in the line. Fuel squirts on dist/coil and voila, flame on. I know, I'm a dumb a$$ for not seeing the possibility but I had no idea how much fuel was gonna come out of there. Luckily I'll just have to do some minor rewiring and replace a couple of vacuum lines (I hope) but damn, if anyone hasn't replaced theirs yet just do it. These things are so bad they're dangerous.
#53
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Anyone try replacing the Holley regulator with one from a TTA? Base pressure is 45psi rather than 37 like the GN unit.
$40 from autozone:
Product Details
Part Number: 800-114
Weight: 0.45 lbs
Warranty: 1 YR
Adjustable Fuel Pressure: Yes
Boost / Vacuum Reference Port: No
Compatible Fuel System Style: Return
Compatible Fuels: Gasoline
Gauge Port: No
Inlet Attachment Type: Straight
Inlet Quantity: 1
Installation Hardware Included: No
Item Grade: OEM Standard
Material: Steel
Operating Pressure: 45 psi
Outlet Attachment Type: Bolt-on Type
Outlet Quantity: 1
Package Contents: Includes Caution Sheet; W/ O-ring
Assuming the outlet is the same thread. Probably order one today. My holley unit stopped reacting to vacum changes. If I pull the line off the pressure doesn't move..
-- Joe
$40 from autozone:
Product Details
Weight: 0.45 lbs
Warranty: 1 YR
Gauge Port: No
Inlet Quantity: 1
Material: Steel
Outlet Quantity: 1
-- Joe
#54
Car: Cobra Kit Car
Engine: 350 HSR
Transmission: TKO 600
Axle/Gears: 3.31
The Holley setup is also based on 45 PSI.
The Kirban 6547 will work from 30 psi till 100 psi.
In my opinion "You should not have any problem"
#55
#56
When I had my HSR it's stock regulator failed. So when I switched to my Pro-Ram I noticed it had the exact same part and I wasn't wanting to go that route again. I had the back inch of the fuel rail cut off and then taped for a -8AN fitting so I could run a nice Aeromotive unit. Works well on my Pro-Ram and from pictures it appears that it might work with the HSR. Just a thought.
9192camaro
16
02-03-2019 12:21 AM
