My heads/cam Hsr
1 Post
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
My heads/cam Hsr
I recently spun a bearing in my L98 so I am soing a rebuild now. I am having the shortblock bored to a 355 and uping the compression a little for the thin air up here at 5,000 - 7,800 ft. I am buying the Trickflow Kenny Duttweiler 195cc runners 64cc combustion chambers and a max lift of .600.
http://store.summitracing.com/partde...970+4294784603
I am also running an HSR and need the best cam for this combo. Which of these cams would yeild the best for a car driven on the weekends, mostly street, some track but not a lot? I would like to keep my SVO 24's but I may need to change. I will be running 1.6 rollers too. How much power can be expected with tuning?
This cam:
63-08-305-8 Comp Cams 276 Hydraulic Roller Camshaft, 220 / 230, .510 / .510 114 LSA, For factory roller cam engines with highly modified TPI and computer.
This cam"
xr276hr-12.
224/230 @ .050, lift intake 0.503 in. exhaust 0.510 in. , 112 lsa
Or this one:
63-08-306-8 Comp Cams 290 Hydraulic Roller Camshaft, 230 / 244, .510 / .540 112 LSA, For factory roller cam engines with TPI, modified computer, intake plenum, runners, and 2500 stall.
Or this one:
http://store.summitracing.com/partde...1&autoview=sku
This cam:
This cam"
xr276hr-12.
Or this one:
Or this one:
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
This cam:
This cam"
xr276hr-12.
Or this one:
Or this one:
This cam:
This cam"
xr276hr-12.
Or this one:
Or this one:
The 306 is the cam I run. bumpy, doesn't like closed loop, etc. The 276 is the came I used to run, on 112lsa. Ran great. The 305 on 114lsa is for a blower.
If the compression is around 10:1 the 276 cam can put out around 360-380 with a HSR, the 306 cam about 100hp more if the right things are done.
-- Joe
1 Post
Car: 00 Camaro SS
Engine: 5.7
Not fishing for anything, thanks for the input
I will be tuning it with a buddy so I'm sure it'll take a bunch of trys to get it right. I actually am picking up a set of AFR 195 Eliminators today so I have some more research to do on a cam.
1 Post
Car: 00 Camaro SS
Engine: 5.7
I just ordered my AFR's for 1,470 shipped and in stock. He recomended this cam, it looks a little small to me though. It's a Crower but he said they can get me Comp cams too.
Hydraulic Roller Cam, Duration @ .050 Intake 209 Exhaust 217. Lift w/1.5 rocker Intake .495 Exhaust .514 LSA 110
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
I'm not real sure about that 110 LSA - I'm thinking that if you kept the 112 you'd be a lot happier... (Both you & the ECM, it'd be a lot easier to tune.)
That's real close to the cam that I've just about decided on for my 383...
Originally Posted by 87tpi
This cam:
xr276hr-12.
xr276hr-12.
Car: 89 vette
Transmission: a4
-- Joe
-- Joe
John
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
-- Joe
Car: 89 vette
Transmission: a4
It runs good other than committing to a life time of tuning. Thats OK though. It's my hobby.
Before the dyno tune I ran 12.16 @112 with a 1.72 60'.
Two weeks later the initial dyno run said I had 317 rwhp.
Then I tuned it to 343rwhp.
I should be high 11's with that.
So How much do you think the 306 cam is worth?
I have been contemplating another cam.
John
John
1 Post
Car: 00 Camaro SS
Engine: 5.7
Ok, I think I have it all figured out, finally.
I'm doing a 355 with stock reground crank, Eagle I beam rods, Probe forged pistons, Afr 195 eliminators, Stealthram and I have narrowed my cam choices to these 3.
XR276HR-12
268XFI-HR13.
CS276HR-14
With the rest of that setup, which of those would be best for my weekend streetmachine? I'm dropping the block off Friday at the machine shop and the heads will be here Thursday.
XR276HR-12
268XFI-HR13.
CS276HR-14
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
curious to see how this runs on a dyno
195cc afr heads ive always thought to be way too much head for a 350, more designed for a 383, unless you planned on reving till 7000
the first cam the 276 is what i have in my motor. Running a stealth ram with 180cc iron eagle heads which is a TOTAL mismatch i know, heads are killing me. with 1.6 rockers youd be getting descent lift out of it but id think youd be looking for more rpm and more lift with those crazy heads, i peaked at 6000 with those heads i wouldnt want to be shifting anywhere before 6500
Car: 1990 Camaro
Engine: 355ci
post dyno numbers, curious to see where in the powerband you make power with that setup.
I was strongly under the impression that the 195's were too big for a 355.
On that size motor those heads are going to want to make peak power at 6500 rpms and the cam is going to cut out around 6100.
I also think the butt dyno isnt going to register anything until you hit 3100rpms.
This is all just what i have come to believe tho, dont have hard numbers behind this, feel free to prove me wrong, im very curious to see how this combo comes out
1 Post
Car: 00 Camaro SS
Engine: 5.7
I have had a couple of people run this combo through there desktop dyno and my machinest ran some and recommended this cam also. I don't really need really high rpms, I just want a mean street machine that'll do low
12 's/high 11's at the track.
This is what the dyno suggested.
430 hp and 455ft lbs. at 5,500 rpm. 390-400ft lbs. from idle up
I will post up #'s after the dyno tune.
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Re: My heads/cam Hsr
maybe as use for reference I was recommended a 234/238 .578/.584 112LSA cam from Cam Motion. This is with a 355 w/ HSR and Pro 1 215's
1 Post
Car: 00 Camaro SS
Engine: 5.7
I got my shortblock back Friday and am puting it together now and I plan on dropping it in, this weekend or next. I still need the rockers, pushrods, and converter before I take it to the dyno. I will post up #'s and plenty of video when it's running.
I have been looking at a different cam, which would you guys recomend between the xr276hr-12 that I said above
http://store.summitracing.com/partde...8&autoview=sku
or the 280XFI HR13
or the 280XFI HR13
86CamaroDan
09-29-2015 10:08 PM
