stealth ram to dart iron eagle 180cc head gasket size
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
can anyone help me out here im having a tough time putting this together
on one website ive seen that the dart iron eagle 180cc take a 1204 gasket, and that the stealth ram uses a 1205
but on other websites ive seen that both the iron eagle and the stealth ram have the same port size.
so im confused
if the stealth ram is a larger port size then my heads then im definitly going to be doing some gasket matching.
and i cant just measure, theyre on the car already
so im confused
Car: 89 S10 Blazer
Engine: 355 tbi
Transmission: Built 700R4 w/ 2500 stall
Axle/Gears: 3:73 posi
Re: stealth ram to dart iron eagle 180cc head gasket size
you find anything out on this?
Car: 1990 Camaro
Engine: 355ci
im still not sure, if youre taking it apart would be pretty simple to just get both gaskets and return the one thats not right.
Havent taken the intake apart yet to bother port matching it, this post is also over a year old
Car: 89 S10 Blazer
Engine: 355 tbi
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, LT1
Transmission: TKX, 4L60E
Axle/Gears: 3.42, 3.23
I don't mind bringing old posts back from the dead to discuss updates. Obviously someone used search!
Better than making 10 posts on the topic with 0 resolutions.
-- Joe
-- Joe
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I used the 1205 with mine. If I recall correctly, the HSR and 1205 gaskets ports were a lot larger than my dart heads. I should've ported the heads to match but didn't.
9192camaro
16
02-03-2019 12:21 AM
ambainb
04-25-2016 09:21 PM
355tpipickup
08-27-2015 08:13 AM
NinjaNife
08-23-2015 11:49 AM
L98GTA87
08-11-2015 06:55 PM
