HSR adjustable regulator
1 Post
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
Has anyone else have problems with the Holley adjustable fuel pressure regulator?
Is there a better one recommended for this fuel rail?
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
this is the one Im using...I forgot where i got it from..when I find it I'll post it...
1 Post
Car: 87 GTA t-top
When I turn the key to on, the pressure measures 40 but goes down to 0 and leaks out where the adjust screw is, when the cars running its all over the place.
Does anyone know the adjustable Kirban or BBK regulator part number for this rail?
thats who its from, Kirban...thats the one I have pictured above..
https://secure.mysuperpageshosting.c...com/index1.htm
part number 6547
part number 6547
Car: 91 camaro z28
Engine: 350 modified
Transmission: 700R4 modified
i've also got the kirban one, love it no problems, before that i went through 4 holley ones.
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Kirban unit for sure. Money well spent.
My holley was constantly changing, flooding, then lean.
Never had a bit of problem with this unit.
Car: 85-Vette
Engine: 406ci
Transmission: TKO-600
Axle/Gears: 3:45
Me too, I called Holley and they told me they would replace it with a new one "IF" I had a receipt, but I bought mine used, unfortuately.
I like the Kirban but the fuel line routing may be an issue
They would't replace mine either, so I said **** them and bought the kirban. What kind of fuel line issues do you think you'll run into? I've seen a lot of guys run these but I've never heard anything about having trouble with fuel lines.
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
yeah in the picture above I did have it turned the opposite way..its turned the right way now...
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
Good thing I havent ordered the holley regulator yet. I was about to get that and the fuel rail kit for the HSR though any problems with that? Where did you find the kirban at?
1 Post
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
My FP is all over the place too. I'm not sure if it's the regulator or the gauge though. I've read about many issues with the stock HSR regulators.
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
If you have a receipt for the purchase of your HSR, Holley will give you a new AFPR "IF" you return the bad AFPR with a receipt.
If any one has a receipt that I could use to get me a new AFPR, I would be willing to pay you half the cost of buying a new one.
You could scan me a copy of the receipt, or I can send you the AFPR and I wil send money for mailing it to Holley, and money for sending it back to me.
email me.
email me.
Car: 92 Formula
Engine: 383 248/256 cam
Transmission: 700r4 3500 stall
Axle/Gears: 9" 3.89 gears detroit locker
Hey I got one when I purchased my stealthram and fuel rail kit from summit.
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Excellent, thanks guys, I'd heard about the problems w/ the HSR afpr, didn't know what I was gonna do since it's been quite a while since I've bought my HSR, & didn't know what other units to try...
1 Post
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Re: HSR adjustable regulator
This site is awesome. I'll be buying the Kirban unit tomorrow. Thanks for the part number and website listing guys! I have a Vortec HSR that I'm installing in my car this week. Heard a few people talking about the AFPR that comes with the HSR fuel rail kit. This seems to be a nice replacement.
Thanks again!
Thanks again!
Thanks again!
Thanks again!
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
if im buying fuel rails but do not want the holley regulator do i still have to order the fuel rails that come with the afpr or can i get the cheaper ones?
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Just got my vortec stealth ram.Inside of that fuelrail package I found quaranteecertificate that says:quarantee 90 days from purchase...
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
Got my Kirban today, awesome piece, well made Billet machined
I decided to keep my holley fuel rails.\ and get the Kirban
If anyone that has a new HSR wants to buy my Holley AFPR cheap, you could send it in for an exchange, and sell the new one, just a thought
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Kirban one kicks ***. I've had mine for about a year now and no problems at all whats so ever.
1 Post
Car: 87 GTA t-top
Got a Kirban already, works good, only thing is getting my engine tweeked to work proper with this setup.
The timing is off as well, I dont think it was a good idea changing intakes, Im rather dissapointed.
1 Post
Car: 87 GTA t-top
Head casting number: 14101083
GenI, crate motor, 285 or 300 hp, 64cc chambers, 72' center manifold bolt.
Stock valve covers.
Stock valve covers.
1 Post
Car: 87 GTA t-top
Im running both lines from the back as well, its the only way I can install without issues.
Theres a few mods that need to be done to get this right, I found it to be a pain since theres no help to install on these cars.
Some trial and error but eventually it works.
i want to get the HSR but i dont want to get the fuel rails with the regulator...is there anyway to get just the fuel rails? then get the kirban one later....i need part #'s/sites etc thanks, good thread i heard about the crap Holley regulators and how everyone uses buick Ttype regulators.
#42
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
Yup finally installed my kirban FPR. this thing is awesome. My fuel presure is dead on now. Car sounds better. My Holley unit was accually bad. Fuel leaked out the vacuum side when i took it off. glad i took everyones advice before something bad happened
#43
UltRoadWarrior9
04-28-2020 10:39 PM
86CamaroDan
09-29-2015 10:08 PM
