cutting and flaring fuel lines?
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Anyone here Ever cut back their fuel lines and reflare them to accept direct AN fittings? I would like to have my fuel lines cut and fixed back by the firewall so I can run my braided line up to my manifold back by the firewall instead. After I cut the line, What fitting would I need to slide on first before flaring the fuel line?
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
It can be done.
However AN flaring tools are pretty expensive for the nice oens to do them properly(unless someone has a dectn cheaper one I'm not aware of)
What I would do, is find someone that has AN fittings/lines near you and scout out what kind of adapters they have and work backwards from there.
Like a metric/standard double flare w/ o-ring for fuel lines or the like and then decide on what fitting(s) to use on the fuel lines.
Also any place that does hydraulic type lines for industrial type stuff will more than likley have or be able to make what u need.
later
Jeremy
later
Jeremy
Car: '02 Z06
Engine: L33 5.7
Thanks Jeremy, Where I work, their is a nice performance corner with lots of earls fittings. I could probably find what I need, I am just not sure even if such things existed in AN sizes to fit a standard size metal tube.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: 1969 Nova
Engine: LT4 Hot Cam L98
Axle/Gears: 3.42 8.5" 10 bolt
Travis, if you can get the lines off, take it down to American Street Rod on south sunrise next to smeding auto. I cannot imagine it being too expensive.
Car: '02 Z06
Engine: L33 5.7
You saying I just bolt those to the stock fittings on my fuel lines?
what angle does the stock fuel lines flare at?
I could cut the lines, stick on the stock fittings, reflare the new fuel line to the stock degree, reuse the stock fittings at the back by the firewall, and use these adapters.. hmmm
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, LT1
Transmission: TKX, 4L60E
Axle/Gears: 3.42, 3.23
-- Joe
Guest
Posts: n/a
Stock fuel lines on a TPI are not flared. Its an o-ring fitting, the o-ring makes the seal whereas on a flare fitting the flare makes the seal.
I've used the Earls adapters, very simple. Just tighten up the nut on the factory hard line to the fitting and you have an AN connection ready to go. No hacking required.
1 Post
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
I have the summit 37 degree flaring tool and it works great. I have tried it on aluminum and steel tubing with no problems. I believe the more expensive flare tools are only necessary for stainless line which is a real b!tch to flare.
Car: '02 Z06
Engine: L33 5.7
Thats how I had it before, But I dont like the lines coming that far forward in the engine bay, but if its going to be a hassle, then I will go the adapter route again.
1 Post
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
dont buy the summit flare tool. i have thier double flare one, and after about 30 or so uses, its already ****ed. stripped out the tool and the stud, and yes i know how to use it, i havent been trying to tighten it like a strut bolt
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Wow, I just posted in another thread so I'll copy here...
I cut my hard lines underneath the car to remove everything from my framerails. I bought the 37 degree falre tool from Summit and it worked flawlessly for my project.
Tube nuts and sleeves work to attach the hose ends to the hard lines. Get one -6an tube nut and sleeve (feed line), one -5an tube nut and sleeve (return line), one -6an connector (two male ends for feed line to new hose), one -5an to -6an adapter (two male ends return line to new hose), four -6an hose ends, and some -6an braided hose. Then connect your new lines and feel great about your project.
BTW use straight hose ends for the hose meeting the old lines and I used 130 degree swivel fittings for the fuel rails.
Car: '02 Z06
Engine: L33 5.7
Thanks man, I think I can handle the project now.
Sometimes I just need someone to hold my hand through it, You don't by chance have any part numbers laying around do ya?
theshackle
03-05-2017 06:37 PM
AkDrifted
08-17-2015 07:45 PM
