AFPR for Holley Stealthram..where to buy?
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Where can I get an aftermarket Adjustable Fuel pressure regulator for the my stealthram?..that will mount in the same location?
Does Areomotive make one?
I have done a search and the link to an aftermarket AFPR doesnt work anymore...I saw a picture of one and it also had a fuel pressure gauge on it.......that would be nice!
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Kirban has a nice one (part 6547) that has worked great on my setup. About $100.
Welcome to Kirban Performance Products
Doesn't have a gauge on it but it does mount in the same location.
It is adjustable without removing the vac line.
The Holley one has given many people problems.
any others?
Glad I did, have had no problems since installed (fuel related anyway)
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Yep, that was enough to sway me away from it.
Thanks for posting that info.
Had it replaced under warrenty
Went to the track
Same thing happened again! Regulator was set at 43.5 both times.
Needless to say it's not fun trying to drive the car when its getting that much fuel.
I didn't have time to wait for the Kirban so I picked up a gn regulator.
I need to pick up the Kirban regulator now because injector duty cycle is wayyyy to high at 90%~
Car: 1989 IROC Camaro
Engine: Stealth Ram 355
Transmission: WC T-5
Axle/Gears: Torsion 3.42 Posi
Look in www.gmhighperformance.com, they have an article about HSR placed on a IROC. It says they used Aeromotive Reg...
Hotrodboba400
12-10-2019 07:07 PM
86CamaroDan
09-29-2015 10:08 PM
