Were to get HSR bolt kit and gaskets??????
Car: 1988 pontiac Trans Am GTA
Engine: DFI,Single Plane,200cc Dart I.E,355
Transmission: Th400 PTC converter
Axle/Gears: Stock Ausie 9 bolt w/3.45 gears
I am buying a HSR set up it is used and it doesn't come with gaskets or bolts so can u guys tell me were to get the bolts from, and what gaskets i need to get and were to get them. i posted say thread on stealthram.com and havent had any replies yet so i hope you guys can help me out..thanx
dave
dave
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Quick search
Just for reference plenum to runner gasket kit is holley p/n
108-119
Bolts are socket head cap screw for the plenum to the base.
don't have one off right now to measure but they can be found locally.
I don't think they are metric.
Manifold base bolts can be std hex heads for any SBC intake.
TB bolts are metric so use caution there.
108-119
i buying a different set-up, it is brand new and has all the bolts..thanx for the help
1 Post
Car: a car being parted out
Engine: blown up
Transmission: in peices
if not go to mcmaster-carr and get 2 of pt #92810A130 (under $6 each)
better than 70 something that holley wants, you just have to buy 4 longer bolts.
i have aftermarket heads that have standard angle, not the L98 head angle...thanx for the insight though, i am happy with the help
dave
dave
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I wouldn't mind having some extra plenum to manifold gaskets but they list for $14 at Summit! Are they any cheaper anywhere else? And are they still the cheap paper ones or made of a more durable material?
1 Post
Engine: blown up
Terrell351
06-13-2021 01:13 PM
ambainb
04-25-2016 09:21 PM
NinjaNife
08-23-2015 11:49 AM
