Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
slp runners or HSR
Old 10-05-2005 | 06:05 PM
3rdgen92maro's Avatar
Car: 1995 Firebird Formula
Transmission: Th350/4k stall
Axle/Gears: 10 bolt with 3.42s
slp runners or HSR
i was just wondering if i should run the slp high flow runners or just breakdown and ditch the TPI and throw on a stealth ram, or some other intake manifold.
Old 10-05-2005 | 07:09 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Don't know the smog laws in your state. The HSR is not 50 state legal.
Old 10-06-2005 | 04:14 PM
rsn932's Avatar
depends if youre looking to keep more low end torque or move to more high RPM horsepower. I had them both and I'd take the HSR any day. The torque loss with the HSR is very overrated, still very easy to spin the tires from a stop.
Old 10-06-2005 | 08:36 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
What about Superram? Smog Leagal, TPI Style, Feasible of making LT1 type power.
Old 10-06-2005 | 08:40 PM
rsn932's Avatar
the super ram is a PITA to work on, even worse than regular TPI setups. the HSR is a breeze...
I'm not saying the HSR is the best, I just happen to like them and think its the most cost effective useful upgrade for TPI f-bodies, except for maybe a converted LT1 intake or a converted singleplane.
Old 10-06-2005 | 08:52 PM
Whats hard about it?
Old 10-07-2005 | 02:27 AM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
From what I have read its a pita to work around the very low wide pleanum and the lids have a tendancy to warp causeing nasty vacume leaks
Old 10-07-2005 | 04:43 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
go with the HSR. you wont be sorry
Old 10-10-2005 | 10:58 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
if ya do a a SR and dont have to take it bakc off its only a PITA once. The Billit lids are just fine.
but you will spend more on a SR then a HSR thats for sure.
Looks I like the SR over the HSR
Ive had em all.
http://www.cecoatings.com/images/coa...s/TPISRHSR.jpg
not in the pic is a SLP setup,LT1 converted,and mini ram.
Old 10-11-2005 | 02:54 PM
but would i have to trim the stock hood supports to clear the HSR
Old 10-11-2005 | 03:09 PM
rsn932's Avatar
possibly, but at the very worst it will be a small rectangle the size of your throttle body that must be cut from the bracing. not a big deal unless you are trying to make a show car. it depends how much your motor mounts have sagged.
Old 10-11-2005 | 03:53 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I had both HSR & SR. The SR is a total pain to work on, but had great mid range punch & pushed the Z into the low 13's. Never had any vacuum leaks. Ask TPI383, he has my old SR. The HSR is a breeze to work on, has power from 2k to 6k & helped get me to the 11's. If you don't need EGR, the HSR rocks.
Old 10-12-2005 | 12:52 PM
thanks for the help. looks like i will be getting a HSR. does anyone know how much it will cost with the fuel rails and everything?
Old 10-15-2005 | 06:40 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
you could get the new manifold/feul rails with afpr for around 600 if im not mistaken. i have someone here that has one new in box but isnt going to use it. hes giving it to me for like 450 with the rails and afpr i cant wait.
MoJoe
Members Camaros
31
10-06-2021 06:38 PM
Linson
09-25-2021 07:55 PM
no green
01-09-2016 09:22 PM
Royal_Z
09-30-2015 08:45 PM
Dragonsys
09-25-2015 03:51 PM
Quick Reply: slp runners or HSR
