Stealthrams and fuel pressure regulators
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Well,
Looks like I will be getting myself a Stealthram when I can get my hands on the vortec version.
I dont see anything that doesnt look cut and dried for me to do when I install it except for the FPR.
Anyone do something different, relocate it, or find another one that works and is accesible without being a hassle?
Just looking for some ideas since I know I have around a mth for I can get a intake.
later
Jeremy
later
Jeremy
Car: Sexy
Engine: Stock
Transmission: Slipping
When I had the HSR AFPR on my car, it was easily accessable. It was literally right there pointing out from the rear of the fuel rail. It just bolts up if you get the adjustable fuel rail set.
1 Post
Can u get to the distrib bolt to set the timing and do it without taking 2 hrs ? lol
Just trying to find out all the particulars.
Is the adjustabel reg. different in size/shape than the non adjustable?
later
Jeremy
later
Jeremy
Car: Sexy
Engine: Stock
AFAIK the regulators are both the same dimensions. I can reach my dist bolt fine, but I have one of those funky wrenches for it.
Car: Sexy
Engine: Stock
True. There isn't a runner in the way. I bought the funky wrench when I had stock TPI on there, you could probably get to it with a universal on a regular socket with a HSR.
1 Post
OK, that makes sense. I wasnt positive from pictures and I always forget to look on a friends car when I get the chance to see it lol.
later
Jeremy
Now I'm just waiting from someone to have them in stock again lol
later
Jeremy
Car: 1991 rs, 1992 z/28
Engine: 363 ci chevy sb
Transmission: 700-r4
check out my thread on hsr fuel rails. i got a reply with good pics of a better adj fpr and some info on getting it installed.
Car: 1991 Formula
Engine: 350 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 3.73
The stock AFPR is a piece of junk. Mine would not hold pressure and would let gas seep out, plus it was also a pain to get to. I bought a Kirban Performance AFPR (it's made for GN's) and it works wonderfully, but is still a pain to adjust. The distributor hold down bolt is real easy to get to now by using a 14 mm wrench with a dip.
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
Do you have part number? Got any pics of it installed?
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I believe he's talking about this one.
Part #6547
https://www.kirbanperformance.com
You guys have me really worried about the one that came with my rails so I might just pick one of these up too.
Part #6547
I don't understand why the regulator would be hard to adjust.
Are you mounting them on the other side?
This is how I have mine setup to go in and it should be cake to adjust.
Car: 89 Formula
Engine: 355
Car: 1991 Formula
Engine: 350 HSR
I tried to mount it the way pictured but when you actually have the intake on, the distributor has to be squeezed in there with the return line arranged like that. I didn't want to take the chance of having a fuel line touching the distributor so I just arranged it the way Holley said via their instructions.
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Anyway, the FPR had to go with the line OUT because it would hit the valve cover..
Its not too bad to adjust with a long flat head..
-- Joe
Car: 87 IROC
Those holley adj fuel reg. really do suck! Today I was adjusting the pressure back to 42 psi and after all that turning it went back to 35 psi. Thats it for me I getting another brand!
Back to the drawing board.
Car: 1991 Formula
Engine: 350 HSR
Have you tried reversing the fuel rails so that they enter/exit near the throttle body as opposed to the distributor? I read somewhere that somebody did it and it worked out well for them. You can't do that with the Kirban AFPR because it is too bulky, but the Holly AFPR may be small enough to work.
Originally posted by Parrydise7
Just out of curiosity, what is the attraction of an AFPR (instead of nonadjustable)?
9192camaro
16
02-03-2019 12:21 AM
