TPI shootout in Feb Super Rod magazine
#101
Originally posted by MikeH
A larger cid engine could use the shorter runners.
Also having been there and done that with several combos.
A used Superram is only maybe 200$ more than a set of LTR big tubes.
Well well worht the 30hp extra topend pop.
#103
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
i have that magazine too,and summit racing sales the superram now for $779 for top half and for base 517 scoggin dickey sales the gm 383 with the super ram install on it.
#104
Originally posted by Orr89RocZ
yeah i have been huntin for a used superram in the 700 dollar range. hope it works out.
I paid $500 for my upper, plenum runners, used.
I bought my SDPC base new.
#105
Car: 83 Trans Am
Engine: 5.7 (350) TPI
Transmission: soon to be 700r4
Axle/Gears: 9-bolt rear. gears? hell if i know
WOOOOHOOO!!!:hail: :hail: :hail:
Right on Ominious! I knew someone would get these scans! I was fortunate enough to find it, I just thought it was very important for all of our fellow members to be able to see this! I cannot thank you enough! :yourock:
P.S. I plan on bringing more members to the boards, now that I am in school. Apparently alot of people in the area are interested.
Fox Valley Thirdgen crew up and coming!
#108
1 Post
Car: 88 5.7 Iroc, 2000 SS
Engine: Vortec Hot cam TPI/LS1
Transmission: Pro-Built/T-56
I would love to find the SR uppers for $500 , would buy it in a heart beat. Where?
I never see the uppers for sale.
I have an Vortec with the hotcam, I'l sure a SR would open it up a little on top.
But did I miss something, or were all the TPI's that performed well extrude honed?
I have As&m runners, and a unported SDPC base. seems as if the extrude hone would be better than a home port, ( DOn't want to hurt anyone's pride) ( Also I have ported heads before , and know that there are alot of potential gains)
What I'm saying is they used an extrude hone and DFI, that has to factor in for something, and yes I know you can tune a car pretty close through the prom.
What I'm saying is they got those #'s with a maxed out TPI, with the highest $quality stuff.
sounds as if we give up alot by running unported equipment. sucks to do if your car runs well already ( tear everything down to port)
My runners and plenum are matched, I need a reason to pull my base and heads
#109
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I have had a
- 10:1 383" heads and zz9 and TPIs big mouth and LTR, great torque but no fun over 5200rpm.
- switched to Superram, better combo if you ask me, pulled hard to 5600rpm
- Changed to 415cui and cc306 cam, Superram pulls to 5200 rpm, will change to HSR this spring and see whats happens....
Just my experiance.
/N.
Just my experiance.
/N.
#110
I got that base, and it is the poorest flowing aftermarket base out of the box.
I put mad time into mine and removed a mad amount of material, I didnt think paying extrude hone would have got me anything more then what I did to it.
But in as cast condition, I would never consider running it on my car, thats how poor I think it is out of the box.
#112
1 Post
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Great article . I had to go out and get it . Thanx to Acceled Z for telling me where to get it up here.
I have a couple of Q's about these tests though . I have alwasy been under the impression that LTR setup's ( like the one I have) don;t see alot of high revs . SO why is a stock TPI makeing power to 6000 rpm ???? It destroys everything I have read ...or seen on a chasis dyno . What made it flow there ????
I love what they say about the Edlebrock unit ......"lot's more room for porting" SO remember that this was tested with a STOCK TB ...and STOCK plenum . The TPIS set up was a matched setup and the plenum was matched too also , they used a bigger TB . The ASM unit had a matched plenum and they tryed different TB's ..... try this with the edlebrock unit as well .....and then see if it's the baddest LTR setup . I think the edlebrock unit is .....nothing personal here .
#113
yeah, superram system for 700 used. i havent seen just the uppers for anything less than what summit sells it for.
i was wondering the same thing about TPI pulling to 6000rpms. the power is flat from 5000 on pretty much. i thought it had to do with that cam cuz it is big. but the intake is on a 383 which should rev even less than 5000rpms. oh well, this seems to re write the books about TPI and those saying only low rpm breather. LOL
the edelbrock unit is nice for the price cuz it isnt ported out of the box. TPIS big mouth is. thats where the extra 100bucks is. lol, so edelbrock is good deal in that if you do porting yourself you can gain same flow characteristics. i seen before and after pics of a golf ball not fitting into the runner holes and after porting, the golf ball easily rolls in and out. so alot of room to do some serious work.
i am somewhat dissappointed that they didnt use SLP runners. they are very popular and cheap and i was curious to see how well they would do. they can be ported out really well and you should see similar numbers as in those tests.
#114
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
this article is awesome!!! it just makes me feel even better since im running the trickflow 195's on my 383 (10.6:1 CR) with the HSR and a 58mm tb and a close enough cam 230/236 .544/.555 after my 1.6 rockers.
i now know im extremly close to my 500hp mark and with some head work i think the smaller cam will get me there. whats holding me back now is the 1 5/8 shorties im running...looks like 1 3/4 are in the midst.
they did run 1 3/4 primaries for the test didnt they????????
#117
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
The stock tpi intake is not 'pulling' to 6000 rpm. Just because it flatlines after 4500 doesn't mean it is still 'pulling'. Pulling would imply that the car is 'pulling' harder, meaning going faster, and that is not happening if the intake is flatlining. The intake is restricting airflow when it flatlines.
#119
1 Post
Car: 1992 Z28
Engine: 355
Originally posted by Red Devil
Looks like 2".
Looks like 2".
#120
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Yes you do. In looking at it again, I think I may have mistook head material for an adapter. In one of the pics, they look to be about the same size as the AS&MTPIS large tubes. :shrug:
I guess that's our first question.
#122
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
yeah but you would expect power to drop off drastically after 5000rpms with stock tpi like what the stock L98 does.
#123
Car: 86 Iroc-Z28
Engine: FB385
Why isn't this a sticky yet? Pretty informative and no one is really getting off track with this. Good thread. Thanks for posting up the article OMINOUS_87 because I would have never found this magazine anywhere around here!
#124
Re: TPI shootout in Feb Super Rod magazine
Originally posted by Acceld Z
AFAIC, the HSR is the winner as far as numbers:$. And i'm a SR guy, lol.
#125
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I still don't know if I agree with HSR being the 'clear' winner on numbers alone. A peak number is as fast as a broader range. Not only that the cam was a little more biased to the SR and the HSR.
As with all of the studies have proven, the SR would have been a lot better with a flat pattern cam. The 219/219 cam was made for the SR, and in most cases is the best to use with the SR (depends on heads).
The AS&M with TPIS BM manifold would have been better with a 270 or 276 cam. It wouldn't have made the same numbers as the HSR, but I have seen broader power bands than what they got.
#126
1 Post
Car: 1992 Z28
Engine: 355
Re: Re: TPI shootout in Feb Super Rod magazine
Originally posted by Tibo
Actually I could make a single or dual plane efi intake for less than the HSR and it would flow as good as the HSR. HSR is good, but not as impressive as I could make one.
#127
1 Post
Car: 1992 Z28
Engine: 355
The "219" cam was designed to work with LPE's CNDd L98 heads and the Super Ram. Those heads have an awesome I/E ratio. That's the same cam I have and I love it.
#128
Car: 86 Iroc-Z28
Engine: FB385
For the miniram guys, what cam do you think would work best with it to achieve maximum power out of a vortec headed 350? The one used in the test or something else? Currently I am using a Hot Cam and would like to get a larger cam in the coming months. I was looking into the XR288 or 282. Any info, insight, opinions, or experiences would help. Thanks
#129
If you are looking to go a lot larger I would say the cc306. It's pretty hard a$$ for tuning and idle, but it makes some serious power. (Not emissions legal either)
#130
Actually, I said that the HSR was the clear winner as far as numbers compared to $ is concerned. Christ, a set of runners is almost as expensive as the HSR.
Personally I like the LTR look and troque, but mine doesn't see much track time at all.
#131
A slightly smaller cam will go faster than a cam that is too big.
Only having Vortec heads, while they flow pretty well out of the box, aren't really an ideal match for the miniram which wants gobs of everything!
Call your favorite cam manufacturer, and tell them what you have and what you want to do, and put the cam THEY tell you to, in that engine. Not what anyone on here says to use.
#132
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Good Cams For TPI
These are cams that will work in the TPI cars. You can also have the cam reground to 112-114 LSA. This will give you enough vacumn and also you have a better chance of passing smog. https://www.thirdgen.org/techbb2/sho...ight=good+cams
#133
Car: 86 Iroc-Z28
Engine: FB385
Yeah, I know that is the best route to go, call up and ask. Just figured I would see who has what. Thanks for the info guys.
edit: Oh, and on a side note, for anyone looking for this magazine, Barnes and Noble should carry it. I picked it up tonight. This is a pretty nice magazine. IMO, better than Super Chevy, Car Craft and maybe even GM Hi Tech. GMHTP is nice for newer f-bodies and newer "Hi-Tech" cars. Pretty interesting featured cars in this mag and some nice write-ups.
#134
Re: Re: Re: TPI shootout in Feb Super Rod magazine
That's great, you do that. It's just that your home made intake wasn't tested in this shoot-out And as soon as you add one of the 4bbl style TBs the cost goes up significantly.
#136
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Thanks for posting the article.
Heres the question. I see that the TPIS big mouth intake was good for 50hp and 35 ft/lb. If I was to put this intake on my car would I get the same 50hp increase on my L98? I realize that they tested this intake on a 383 with heads and cam. My engine is obviously putting out less power to start with than the 383 so will the overall gain be less or remain the same? Sorry if this is a dumb question.
#137
1 Post
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
How in the world did the stock TPI pull past 6000 RPM's on a 383??? It should completely dies after 4800.
#138
It did die. Even though the HP numbers remained about the same, the torque at each point was much less as the engine speed climbed. So even if it had 250hp at 6,500rpm or whatever, it still didn't have enough torque to accelorate much more. The reason the HP remained nearly constant is because of the way the HP formula works.
#139
1 Post
Car: 1989 Iroc-Z
I can't find this magazine anywhere. I tried 7/11, Wal-Mart, Target, Barns Noble. Is there anywhere online I can purchase it?
#141
Car: Tree Huggers
Engine: Do Not
You don't want the most HP under the curve, you want the most TQ under the curve, which would mean a nice flat torque curve, which typically translates into a nice HP curve, as HP is a function of TQ. If you look at the Holley EFI graph, you'll see a nice flat TQ curve.
As for the shifting question restate it and... what is the combo? Where is the power band? What do I have for a TC? Those all play factors.
#142
1 Post
Car: 1989 IROC-Z
Originally posted by Thirdgen89GTA
It did die. Even though the HP numbers remained about the same, the torque at each point was much less as the engine speed climbed. .
It didn't die ...it maintained the same HP( THIS IS wierd ) ....all chasis runs I have seen with TPI ...it falls of heavily after 4800 ish .... it certainly doesnt make the same power by any means. That is the wierd thing here . But I think I seen something mentioned about a "timeing event " that helped it .....or maybe I was dreamnig when I read that LOL
#143
Car: 1991 Camaro Z28
Engine: TPI 5.7 L
Transmission: 4L60 w/Vigilante 2,400 Stall
Axle/Gears: Girdled 10 bolt/3.23's
#144
In the TPIS catalog, they claim 20 HP on a stock L98. You'll probably pick up an additional 15 Ft Lbs. as well. This is the route I'm planning, unless the BBK intake changes my mind. I like my 3.23's and the gas mileage too.
Yea I have 3.27 gears and I'll probably stick with them since my car does see some highway miles. Some 3.73 would be nice but a little too low for me on the interstate. I'd like some 3.45 but probably not worth the money for that minor of a change.
#145
Car: Tree Huggers
Engine: Do Not
http://www.azspeed-marine.com/19latuinru.html
Why not get the runners from the company that makes them?
Same could go for the baseplate, but at least TPIS ports that.
#146
Engine: TPI 5.7 L
For the $$$, probably not the best route but I like the TPI looks as well and if you're going to keep it, you don't have many choices besides TPIS or AS&M. The intake can easily support enough power with heads and cam to run mid to low 12's with 3.23's. If that's not quick enough, you can always go the SC, Turbo or NOS route. As far as price, also keep in mind you'll need gears and a converter to get the most out of a MR or HSR set-up.
#147
So TPIS buys the parts from arizona speed and then marks up the price and resells them. Do they port both the runners and the base? I didn't see the base manifold on arizona speeds website, do you have to call them or something? How well does the stock TPI plenum flow? Does it need to be ported or port matched?
What about the throttle body, does it flow well enough or should it be upgraded to a 52mm piece or would that be overkill?
I really like the look of the stock TPI setup and the intake makes nice torque. I don't want to give up any torque like some of the intakes do which is why I'm interested in the big mouth intake. I just don't like how the stock TPI starts to die off after 4500 rpm. It would be nice to have power gains all the way up to 5500 rpm.
#148
Engine: TPI 5.7 L
Don't quote me on this, but I believe Edelbrock makes the base for TPIS. I read it here a couple years back.
#150
I estimated the HP and TQ numbers from the articles graphs using a squaring ruler for the numerical chart listed below. If HP vs TQ came out different than what they should have calculated, I split the difference to come up with the following numbers. So the numbers should be fairly accurate. I plugged the HP and TQ numbers for the TPiS, ASR, and HSR intake systems into a worksheet to get an overlay of sorts from the top three intakes (in my opinion). Im only listing the HP numbers,, which were painful enough to put in this format.
RPM -- TPI -- TPiS - ASM -- ASR -- HSP -- HSR - MR
2600 - 200 -- 207 -- 198 -- 188 -- 190 -- 190 -- 186
2800 - 222 -- 235 -- 221 -- 205 -- 206 -- 206 -- 202
3000 - 260 -- 271 -- 262 -- 240 -- 230 -- 237 -- 215
3200 - 290 -- 308 -- 290 -- 278 -- 258 -- 270 -- 258
3400 - 316 -- 332 -- 319 -- 314 -- 286 -- 297 -- 282
3600 - 338 -- 355 -- 340 -- 337 -- 307 -- 320 -- 308
3800 - 360 -- 381 -- 360 -- 359 -- 332 -- 340 -- 328
4000 - 379 -- 410 -- 383 -- 382 -- 357 -- 363 -- 348
4200 - 390 -- 420 -- 408 -- 405 -- 377 -- 387 -- 370
4400 - 400 -- 438 -- 422 -- 421 -- 398 -- 411 -- 388
4600 - 406 -- 441 -- 440 -- 430 -- 418 -- 431 -- 409
4800 - 410 -- 448 -- 450 -- 443 -- 440 -- 449 -- 425
5000 - 409 -- 453 -- 457 -- 453 -- 456 -- 460 -- 449
5200 - 410 -- 447 -- 463 -- 470 -- 465 -- 475 -- 468
5400 - 407 -- 445 -- 460 -- 474 -- 475 -- 485 -- 475
5600 - 409 -- 448 -- 452 -- 480 -- 488 -- 497 -- 485
5800 - 407 -- 450 -- 450 -- 474 -- 493 -- 499 -- 500
6000 - 406 -- 450 -- 449 -- 453 -- 490 -- 501 -- 501
6200 - 404 -- 448 -- 448 -- 452 -- 486 -- 495 -- 504
TPI - Stock TPI, unported plenum, 47mm t/b
TPIS Stock Extrude Honed base, TPiS LTR, ported plenum, 52mm (similar curve to TPiS base)
ASM - BigMouth base, AZ S&M Semi-Siamessed Tubes, ported plenum, 52mm
ASR BigMouth base, Accel SuperRam Upper, Accel 1000cfm (edit)
HSP - Holley Single Plane MPFI, 1000cfm 4bbl T/B
HSR - Holley StealthRam, 58mm (edit)
MR - TPiS MiniRam, 52mm
Best numbers generated by system (variance of 3hp) from to rpm listed.
TPiS System (207 441hp) from 2600 4600 rpm
ASM System (440 457hp) from 4600 5000 rpm
HSR System (460 -501 hp) from 5000 6000 rpm
MR System (500 504hp) from 5800 6400 rpm
