Lunati- HIGHLY RECOMMENDED
1 Post
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
About a month ago I was shopping around for a custom grind cam to put in my 383. I am very particular with this engine and didn't want to make any comprimises. So talking with and emailing different cam companies frustrated me because they didn't want to talk about your choice or tell you why they recommended the numbers that they did. Thats when I talked to Steve Slavik at Lunati. Not only did we come up with a grind that suits my wants and his logic, but this is a stand up guy who really knows his cams. Anyone looking for a custom grind cam or just a recommendation, please contact Lunati and Steve Slavik if possible. Plus, these voodoo cams are a very quality piece with a price that I cant complain about.
1 Post
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: Lunati- HIGHLY RECOMMENDED
Steve isn't afraid to give you his opinion on things and WHY he thinks that way. I've had many conversations with him, and he's even called me when he got out of work several times to continue the conversations we've had so he could further explain things clearly.
Steve is a great guy in general. It's between him or Rich at BulletRacing that I speak with.
1 Post
Car: '91 Camaro RS
Engine: Carb'd 383
For sure. I felt like the other guys just wanted to sell me a cam, but he wanted to sell me THE RIGHT cam. And we also talked about cam design and how everything works together. What makes it better is these voodoo desgins cam from Harold Brookshire, why wouldnt you buy Lunati?
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Another great guy to talk to is Tim at Bullet Cams, he helped me with my grind and explained to me why I should and shouldn't do some things. I think the guys from Bullet all came from Lunati
