Anyone order from autotous.com ?
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I haven't, and probably will not. I was, and still am looking for a good quality set of H4 housings for a headlight upgrade. On their site, I found a nice housing by Hella, adapter socket and bulb included (I don't need the socket as I already have a set of Pilot H4 lights), but the product description stated "Not compatible with Camaro or Firebird."
http://www.autotoys.com/x/product.php?productid=550
Why? My headlights are 4" X 6.5", and I already run a set of H4 lights the same size, so I thought I'd ask the question on the submit question page (it's manned 24hrs). Back and forth through a series of 3 e-mails each, they insisted that my lights are a different size and that this is not 4 X 6.5, here goes with just the message bodies of the e-mails
To my question as to why they aren't compatible after reading the product description:
My reply
autotoys.com
My next reply
autotoys.com
I have since found the same housing (also available in pairs under a different part number) at Summit and posed the same question to them, and referenced my experience with autotoys.com and this was their reply:
I had the same suspicion about the early 4th gens also since no year was referenced, but the tech on the other end insisted that they won't fit. I'll soon be ordering my housings from Summit.
Not compatible
Thanks, that's a really simple answer to something I already knew from the info in your website. What I asked is why are they not compatible.
Because your headlights are not the size listed.
I have a 4 headlight system, each light measures 4" X 6.5". Correct me if I'm wrong, but doesn't 165mm convert to approximately 6.5"? Camaros starting in model year 1993 have a smaller sized headlight. If these fit where a 4X6.5 inch sealed beam headlight fits, then they should work for me.
No. It won't fit. We are going to tell you this for the third time. And it is not 4 x 6.5
These are designed to replace a typical 4656 sealed beam headlight. They are 164mm x 103mm lights which is 6.45" x 4.05". The actual outside dimensions of the light is 167mm wide x 107mm tall. This equates to 6.57" x 4.21". The HLA-003177801 is a pair of these 003177862 lights.
You will need to check with the other company to find out why and what year Camaro/Firebirds they are referring to. Perhaps they are referring to the early 4th gen's that use the 4351/4352 headlights which are smaller 50mm x 135mm?
Thanks,
Mark
Thanks,
Mark
Re: Anyone order from autotous.com ?
http://www.rallylights.com/detail.aspx?ID=1787
http://www.rallylights.com/detail.aspx?ID=64
try these guys i use them
Thirdgen89GTA
11-26-2015 11:04 PM
