6054 Houseings With HID
Car: 1990 Firebird Formula
Engine: 305 TBI (L03)
Transmission: THM-700R4
Axle/Gears: GM 10 Bolt
HEy anyone use these with HID I was gonna go with a set from that rice company Piolt auto but everyone rated them bad and said they scater even worse then others so i found these that look like they might focus the beam better i am ordering the kit tonight i just need to find good houseings lol the kit i am ordering is http://www.vvme.com/12v-5055w-h43900...cPath=44_46_35
but the had part is finding some nice houseings i seen one guy do this kit on his saturn with the stock hosueings and the beam was not scatered at all just got to find aftermarket ones that are good.
any info or ideas of what may be good ones would be very very helpful
thanx
thanx
Re: 6054 Houseings With HID
also seen there "projector" houseings for 35 bucks something seams odd for that price tho
Camaro:
Hella HL66490 Adapter for 165mm Sealed Beams to H4 Lamps
http://www.rallylights.com/detail.aspx?ID=120 [/URL]
Hella H6545 165mm ECE Hi-Lo H4 Conversion Headlamp Kit
H6545 165mm ECE H4 Hi-Lo Conversion Headlamp Kit.
Replaces 4652, H4656, H4666 H4668, H6545, H6545BL, and HP6545 Sealed Beams. Includes two lamps, two wiring adapters and two H4 bulbs.
http://www.rallylights.com/detail.aspx?ID=64
Hella H4651 165mm H1 E-code Conversion High Beam Headlamp Kit
H4651 165mm H1 Conversion High Beam E-code Headlamp Kit.
Replace 4651, 4740 and 5051 sealed beams.
Kits includes two lamps and two H1 bulbs.
http://www.rallylights.com/detail.aspx?ID=4069
Firebird Trans AM:
Hella "E-Code" HL79567 200mm(H6054) Rectangular ECE H4 Headlamp
http://www.rallylights.com/detail.aspx?ID=354
Firebird Trans AM:
I trust this guy because I have bought from Susquehanna MotorSports
this is the one that you need: http://www.rallylights.com/detail.aspx?ID=744
