Best Place to buy a Zexel T2r?
1 Post
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
What is the best/cheapest place to purchase a Zexel Torsen T2R posi?
Thanks!
Bill
Thanks!
Bill
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: Best Place to buy a Zexel T2r?
try www.stranoparts.com
Best to call them up since finding the part on the site is kind of hard, if it is even listed.
Found it on their site. they did a redesign,
http://www.stranoparts.com/partdetai...D=0&ModelID=10
Part #: GM7AT28HB
Brand: Torsen
Price: $595.00
Helical, High-bias ratio Torsen Race unit.
Used to win multiple SCCA Solo Championships and 2005 SCCA Runoffs Pole Position in T2.
Notes: For use in GM 7.5 & 7.625" 10-bolts w/28 spline axles only. Will not work with 4.10's, 3.73 may require slight grinding for installation
Brand: Torsen
Price: $595.00
1 Post
Thanks! Can you tell me if my car is definately a 10 bolt with 28 spline axles? (I think that's what the T2R needs) I have a 91 GTA with a factory POSI (G80)
Also, I was thinking about regearing while I was having the posi replaced. What's a good all-around gearing (street, circle, autox, drag?) Where can I buy replacement gears?
Thanks!
Bill
Thanks!
Bill
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
I'm 90% sure that the 90+ rears got the 28 spline axles along with the 7.625" moniker, rather than 7.5". I dunno if the ring gear actually went up to 7.625" though.
3.23 or 3.73 are all-around gears. Go with the '.23's if it's gonna be a street car first, and an event car second. And if I recall correctly, if you're road racing or doing autox, a lot of people will upgrade to a Ford 9" just so they can change their gears to match the track they're on. You can get replacement gear sets from any of the board vendors, and probably summit. Just do a search on your brand and part number, some are notorious for squealing like demons.
1 Post
If it's a weekend crusier, would 3.73 be better? The website says that the 3.73's need to be ground to fit. Will this grinding cause issues?
Car: 92 Trans Am
Engine: 383 Stealth Ram
Transmission: 4L60
Axle/Gears: 3.42/10 bolt
3.23 is a great highway gear, but other than that it makes our cars pooches with stock engines. 3.73 is the typical gearing that most go to, and with the 700R4 cruise RPM is still not bad. I actually went with a 3.42 gear (found a lot in S10s) to try and find a compromise between the two.
I got my High Biased Zexel from Reider Racing.
http://www.reiderracing.com/
Was $600.00 after shipping.
1 Post
Ozz, thanks! is the High Biased Zexel the same as the T2R?
Kawtipping, thanks! Does upgrading to a 3.73 have any negative effects like compromising top speed for faster acceleration?
Axle/Gears: 3.27 BW
The bigger you go numerically, the lower your top speed goes. It's a fact of life. The downside is you can't exactly experiment. 3.73 would be a good weekend cruiser. Wouldn't go over that for a car that sees street time. I do a lot of distance driving so the 3.27's are good for me.
The High Biased, according to the tech I spoke to at Reider racing is the one with the extra clutches in it, I'm pretty sure that's the same as the t2R...Reider doesn't sell anything else even though their website says they do. They also tried to sell me one of the Truetrac units which apparently is basically the same thing.
1 Post
You said the stop speed decreases. Where will I feel the car start to suck with 3:73s?
Are they still the best choice for drag, circle track, auto x, etc?
I have 3.73 and love them, but I also have a T56 trans. I use the car for cruising, lapping days, and autox.
If your using a 700r4 trans, then your mileage will be affected at anything higher than 60 MPH with 3.73s.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I dont know if it is the BEST place to buy but I think you can order direct from Torsen now. I asked about a diff for a Dana 44 a few weeks ago and they said they would have on their website soon.
Unfortunately the store page is not loading for me right now
Thanks for the input guys. I sent Torsen an email on Monday but haven't heard back yet. scooter, thanks for the link somehow i wasn't able to dig it up in their shop!
Anyone wants to comment on the T-2R go ahead, i'm interested in the way it performs and how it's holding up to some abuse Sorry if you think this is graveyard-thread-hijacking lol
Been driving mine for about 10k miles so far and other than going through a pinion bearing, pretty sure it was set up wrong by the shop, it's held up really well. Watch out for wet or snowy conditions though. This rear won't act like an open diff if both wheels lose traction, so it will constantly slip the car to the right if you don't keep it on the brakes at a stop light.
Car: 92 Firebird
Engine: 4.8 LR4
I have one for my 8.6" 10 bolt but I havent gotten it installed yet. I also plan on getting it for my Corvette Dana 44 I am going to put in the Firebird
BumpaD82
02-26-2016 02:57 PM
MikkoV
09-09-2015 04:25 PM
