What do you think of POR 15 or Eastwood's Rust Encapsulator?
I have a 1991 Camaro Z28 with severe rust spots. I want to find reputation and quality of these companies. Your responses will greatly appreciated. Thank you.
Car: 89 RS
Engine: LO3
Transmission: TH700R4
POR 15
I have coated a lot of under car equipment with it and I like it a lot. I am currently in the process of refinishing my floorpans with it. Really good stuff and if you search the msg. boards for it you will get a lot of good info.
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
DO you have any pics of POR-15 painted areas?
I was wondering what POR-15 is all about. Is it an actual paint, or just a rust-blocker, which needs to be painted over.
thanks,
KZad
thanks,
KZad
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
bonds to rust stops it. it is a paint. you can paint over it, but it needs to be sanded.
stuf is hard as nails, not really any need to paint over it.
So it really is the perfect, and only, product needed to paint a rusty old rear to put in my car? AWESOME.
thanks,
KZad
thanks,
KZad
http://www.por15.com/Default.asp?
POR-15 users i have a couple questions
https://www.thirdgen.org/techbb2/sho...&highlight=por
Hope that helps!
Car: 89 RS
Engine: LO3
My results
I did my floors and they came out pretty good... just make sure that you prep it EXACTLY as directed. I had a couple of spots that could have been preped better and POR did not stick.
For you experienced users, any tips for preping where the original paint is still holding strong?
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Eastwoods rust encapsulator is a great product.I think it used to be called Coroless.To be honest I've had better results with this than POR-15.ERE is basically a primer and can be sprayed on top of etch primer and then covered in 2-pack or smoothrite etc.I've seen parts painted like this immersed in water for a few years,and not a speck of rust has come through.POR is fine stuff,but it's a bit agricultural.Great if you want to paint over rust but why not just get rid of it.
my painter is using a product that he says is just as good as por 15 and 1/2 the cost. its called sims, or simz, not positive which, but he has a dump trailer that he painted with it 12 years ago and it still looks good. and yes the trailer is used regulary and stored out doors. just something else to look into
1 Post
Car: 1983 Trans Am
Engine: 305 LG4
Originally posted by Dr G
Take a look at these links and the below pic:-
Hope that helps!
Hope that helps!
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
POR 15...love the stuff. My Iroc's entire suspension os covered in it:
http://f1.pg.photos.yahoo.com/ph/tar...m/taramiller72
[MN] S&W 8 point rollcage
FueledSoul
09-30-2015 09:18 PM
tcflint
09-27-2015 05:58 PM
