Ground Control / Unbalanced Engineering
Any one have any experience in dealing with these vendors?
I am considering a purchase of springs, panhard bar, weight jacks etc.
at 5 t/a
What do you use your car for?
How do the weight jacks install and work?
How about the camber plates? How much more camber can I gain?
I called ground control, however the person that I spoke with did not instill confidence.
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
I have the unbalanced engineering heim LCAs and PHR. They work great. Those guys are local to me and they run on the NASA circuit with their gear. There are many guys here in socal they have their gear installed. their customer service is great as well.
I use it for street driving and show. I bought the kit that does not require welding. The front is a weight jack setup that is adjusted with a 1/2 drive ratchet from the bottom side of the a arm. The rear looks close to a coil-over setup,a threaded adjuster sets where the stock spring was positioned. Thread the adjusting nut up or down to your desired height. As far as the camber plates go I do not know how much more camber you can get, I bought these to get rid of the factory rubber pieces that were worn out plus they give you some extra shock travel if your car is lowered. Hope this helps.
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I have the Ground Control Caster/Camber Adjusters and Upper Stress Bar (Strut Tower Brace).
Very happy with the quality.
Mainly wanted the increased travel and steel bearings in the adjusters, plus car's very low and wanted less negative camber to save my tires a little. (car's street driven)
At -1.5 deg camber, +5.5 deg caster.
Guy that aligned my frontend runs in NASA and was very familiar with the Ground Control units.
-Rich-
-Rich-
eightsixseven
08-14-2015 03:09 PM
