Top down Solution...Two Thumbs Up!!!
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Just as an fyi, I got my rear hatch pulldown motor rebuild kit today fro Top Down Solutions, and in the span of about 2 hours I finished the rebuild from start to finish.
Ordered the Kit from Lon at Top Down Solutions and I just wanted to say that there were no surprises, everthing went smoothly and I would not hesitate ordering anything from him in the future!!!!
Just thought I would pass along my good experience for others.
Dave
Dave
Car: A few
Engine: All Eights
Transmission: All kinds
Ditto here...
...well, not quite, but close.
I ordered two headlight motor kits from Lon and used one right away. Excellent instructions, plus the parts made a perfect fit. Now the passenger side seems slow. Time to dig back in there...
I also purchased TDS's Steering Brace. Excellent quality again. And the handling...Night and day difference up front, night-and-frea--king-day.
Peace,
K
Peace,
K
Car: 91 Z28 Vert
Transmission: TKO
"Did you mean to post this in the vendor board?"
I wasnt really sure where to put it, guess I should have went with my 1st instinct.
Thanks for sharing your experiences.
Yes, if you want to share your experience (good or bad) with a vendor it should have been posted to the "Aftermarket Vendor Review Board", (must be why I keep checking there). If you wanted to share your experience with the "XYZ" product you installed, then the "Aftermarket Product Review Board" is the place to post it.
Since in this case you mentioned both a specific product and vendor it could be posted under both boards.
Can this be moved to the correct boards please?
Lon Salgren
Top-Down Solutions
Lon Salgren
Top-Down Solutions
