Auburn Pro Differential, and Moser Gears
Car: 1992 Camaro
Engine: 350 miniram
Do any of you guys use this diff. What do you think about it? I am considering purchasing a 4th gen rear for my camaro and it has the Auburn Pro diff, and Moser 3.73 gears. The guy said it does whine a little, but from what he says it's not that bad. Does that sound like a problem or do some gears just make a little noise? One last thing it has an aluminum cover with bearing support bolts, what does that do?
I have an Auburn diff and for the most part it has done it's job, but if I had it to do all over again I would have went with a detroit locker. As for the gears whining, gears installed correctly shouldn't howl or whine. I had a howl in my previous rearend, and about 6 months later i broke two teeth off of the pinion gear. Howling sends hormonic vibrations through the gears and diff which will eventually make them brittle.
92 Camaro Z28
350 TPI
Dart Iron Eagle heads
10.5:1 cr
Lunati L54779 cam
52mm throttle body
Ported plenum
Home made AFPR ($2)
1 5/8 shorty headers
Ram air
255 lph Holley fuel pump
2.5 inch TRUE DUAL exhaust (no cats)
Flowmaster mufflers
4.10 gears
700R4 w/2000 stall
100HP nitrous
Best time before any of these mods:
15.1 @ 91.9
Best time after mods:
12.60 @ 108.3
That is at high alt.
5600 feet Morrison, Colorado Bandimere Speedway
92 Camaro Z28
350 TPI
10.5:1 cr
Lunati L54779 cam
52mm throttle body
Ported plenum
Home made AFPR ($2)
Ram air
Flowmaster mufflers
4.10 gears
700R4 w/2000 stall
100HP nitrous
15.1 @ 91.9
12.60 @ 108.3
Well, some rears I have seen setup had a whine. Actually, my rear right now whines . It's been doing it all year without any problem. The only rear that didn't whine on me was the stock one that I miss so badly.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (5200rpm limit),Holley 9mm wires,Ac delco R43ts plugs,stock chip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Car: 1992 Camaro
Engine: 350 miniram
That's exactly what I was thinking.
I have heard that Richmonds always make a whine no matter how you set them up. So Moser gears making a little whine doesn't really bother me.
Hotrodboba400
12-10-2019 07:07 PM
86CamaroDan
09-29-2015 10:08 PM
UltRoadWarrior9
09-02-2015 08:24 PM
