Edelbrock Strut tower brace....doesn't fit!!!!
Car: 1991 GTA
I have a 91 GTA with the 305 engine. I ordered one of the Edelbrock STBs and spent all this time drilling holes and lining everything up, then when I finally got the STB in and went to shut the hood, I couldn't. It sat too high.
It has nothing to do with the insulation on the hood. Even if I rest the bar on top of my throttle body, I still cant shut the hood, so i know it is not an incorrect placement on my part.
Has anyone else had problems with these braces not fiting?
check in the suspension section, somebody else with a edelbrock and a GTA had problems. Mine fit fine on a Z-28. Good luck.
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC, 3.42's, Edelbrock STB, 350 in the works
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
1 Post
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Hmm, mine fit, but I have the TBI one for my car. I am guessing urs is the TPI. (Duh Eric)
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Mine fit OK on my 85 TPI engine. I need to adjust it so it doesn't rub too hard on the hood insulation, but my hood closes fine.
James
1985 Z-28 305 TPI
221,000+ mi., Original Eng.
James
1985 Z-28 305 TPI
Car: 88 Firebird WS6
I have an 88 formula without the hood insulation and it rubs on the hood bracing a little bit. (Shiny metal)
1 Post
Car: '85 IROC
I have one on my carb engine. Don't know how similar they are, but it won't work too well upside-down. That's how I first tried to fit it because the decal had beem stuch on the wrong side. (I emailed Edelbrock and they sent me a whole pile of different size decals. If I put them all on, I should be able to go 200 mph! )
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Posi, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
