which spark plug wires should i use with headers???
I want low resitance wires with a 90* boot, and i want them to be blue that i can use with my headers.. Im thinking Tayler wires, but don't know which ones..
what does everyone else use? what is the part # for taylor wires with 90* boots?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Wires
They're probably not the blue color you want,(grey) but go to your local Kragen store and ask for the "Borg Warner Nascar Select" can't recall the part # (they are for a '93 Chevy trk (8mm) w/coil wire and 90Degree boots). They will check out @ about 2k-2.5k and will set you back a whopping $40. None better IMHO.
Don>>>
Don>>>
I've opened my hood and found my accel wires laying on a header (and not burned) to many times, not to recommend them
super stocks, for $30 are good, Spiral cores, for $45 are better, and they come in any color
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Jacobs all the way. They are about $90.00 but they are gauranteed for life. It doesn't matter if they even get burnt, they'll replace them for free. Plus they are 8.5mm, blue, and sprial core.
1992 Trans Am
05-10-2023 07:19 PM
eightsixseven
08-14-2015 03:09 PM
